Go to Post Inside Dave's Head (which is a place I'd like to go someday, but I'm not entirely sure what I'd find)... - Ian Curtis [more]
Unread 28-01-2016, 00:05
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
Rookie Year: 2012
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Tire pressure
What tire pressure have team found best to use with Andymark 8 inch pneumatic tires ?
Unread 28-01-2016, 00:42
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Tire pressure
Right now, on an 8 wheel drive with the center 4 dropped 3/16 inch, we have 20 psi in the center 4, and 10 in the outer 4. So far looks like its going to work. Just get it running and vary the pressure up and down till you see what works.
2016 Central Illinois Winner. Curie Division finalist
Unread 28-01-2016, 01:05
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Re: Tire pressure
From other hobbies involving tires, I would guess that you want to go as low as possible while avoiding pinch flats (where the wheel rim contacts the ground, pinching the inner tube and putting two nice little holes in it). Low psi gives better cushion, but too low and you'll pop tubes. This will vary depending on your robot weight/geometry/driver aggressiveness.
We were close to 15psi in all of our tires during this test, and came close to pinching the tubes. I would guess that ~20-30psi would be more desirable if you intend to ram the defenses.
Unread 28-01-2016, 10:06
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Tire pressure
And remember, low pressure tires don't allow your robot to turn as easily as more inflated ones will.
"A genius is just a talented person who does his homework" T. Edison
Unread 28-01-2016, 12:20
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Re: Tire pressure
I'd say there is no universal tire pressure that will work well on every robot.
The contact patch of the tire is dependent on the ratio of the load on the wheel vs its pressure. A light robot with lower pressure will have the same contact patch as a heavy robot with higher pressure.
I'd also suggest that it may be a good idea to run different pressures for the wheels that are dropped vs the other wheels assuming you have a 6 or 8wd with a dropped center(s).
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 28-01-2016, 19:22
doctorflems doctorflems is offline
FRC #4506 (PioNerds)
Rookie Year: 2015
doctorflems is an unknown quantity at this point
Re: Tire pressure
Another solution to your problem is to, instead of using an inner tube, use a foam rod. That way, there will be no pinch flats and plenty of cushion. Besides, if you are going to ram the defenses, you will want minimal bouncing.
