Go to Post Because of the silly "What's the best 254 team" thread I recently found there is an Electric Sheep! 2546. TBA also says 2505 is The Electric Sheep But which team is the one androids dream of? - Katie_UPS [more]
Unread 28-01-2016, 01:11
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
Team Role: Coach
Rookie Year: 2011
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Fitting a Magnetic Encoder on Ball Shifter
Hey all,
We recently purchased our first 3 Cim Ball Shifter from Vex as well as the SRX Mag Encoder. Anyone have experience on how to mount the encoder to the gearbox?
Thx,
Daniel
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 28-01-2016, 01:18
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Fitting a Magnetic Encoder on Ball Shifter
The 3CIM ball shifter is designed to fit a grayhill encoder rather than a CTR mag encoder
It is probably easiest to mount the mag encoder to an outer axle rather than directly onto the gearbox( this is dependent on having access to a lathe.)
This document show potential installation methods
http://content.vexrobotics.com/vexpr...User-Guide.pdf
Unread 28-01-2016, 02:22
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
First we tried printing the bottom half of the shell, but adding legs to make it a single mount and sensor holding setup. Turns out re-making something that someone already made is a waste of time, so we wound up designing a simple little printed "bracket" to mount the mag encoder for our solution.
Here's an early print of the mag encoder bracket. If you'd like, I can send you the CAD for it. (that print was NASTY. Z-offset wasn't dialed in, the bed wasn't quite leveled right, and the temp settings weren't dialed in yet)
If you have 3D printing ability, it makes mounting these a breeze.
Edit: Here's the .stl for the mount. The central holes are sized appropriately based off the SRX Mag Encoder housing, and the center hole is large enough to allow spacing of the magnetic plug. Using barely oversized plastic also allows you to align the sensor to the magnetic. Turns out slop can be useful!
