Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
Unread 28-01-2016, 16:40
rushtone rushtone is offline
FRC #4188
rushtone is an unknown quantity at this point
Can't connect to roboRIO web dashboard
I'm trying to update the firmware on a fresh new roboRIO, but cannot get a web browser to connect to it.
I'm connected via USB from a Win 10 laptop, and using Internet Explorer it fails to connect to http://172.22.11.2
The laptop has the FRC update suite installed, the NI USBLAN is there, I have an IP address from it (172.22.11.1) and can ping 172.22.11.2. There are no other active network connections on either the laptop or the roboRIO.
David
Unread 28-01-2016, 22:18
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Re: Can't connect to roboRIO web dashboard
do you have NPAPI installed (specifically Silverlight??) you can check by - Type silverlight in your Start search box. If you see Microsoft Silverlight at the top, you had it installed.
OR, Start button > All Programs > scroll down to find Microsoft Silverlight. You find it, you got it.
- from http://answers.microsoft.com/en-us/w...#ThreadAnswers
It may be in the roborio itself, but this could explain the issue with the web interface.
Unread 29-01-2016, 10:06
FRC #4188
Yes, Microsoft Silverlight does show up in my start menu.
Plus the message is "Hmm, we can't reach this page" rather than something like "you need the Silverlight plugin".
David
Unread 29-01-2016, 10:28
FRC #4188
Bah!
When I hit http://172.22.11.2/ from Chrome, I get "Please install the Silverlight plugin".
When I follow the link there to install Silverlight, the installer tells me that it's already installed.
I can't win.
Unread 29-01-2016, 10:38
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Chrome no longer supports NPAPI plugins. Try Firefox.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 29-01-2016, 10:40
FRC #4188
Okay, Firefox seems to be happy to use the installed Silverlight plugin, so I've got the web dashboard. Now if I can only find the firmware file....
Found it, and it's transferring the update image.
Thanks for everyone's help.
Unread 29-01-2016, 10:43
EmileH's Avatar
AKA: Emile Hamwey
Rookie Year: 2011
From the WPI screensteps site on upgrading firmware,
Browse to Program Files\National Instruments\Shared\Firmware\cRIO\76F2\ Program Files(x86) on 64 bit and select the latest firmware, then click Open (this image shows version 2.0.0f1).
Unread 29-01-2016, 10:49
FRC #4188
Yeah, both "Program Files" and "Program Files (x86)" had National Semiconductor\Shared directories, but on this 64-bit laptop I found the firmware only under the x86 (32 bit) path.
Thanks.
David
