Go to Post This is a risk. Life is full of risks. FIRST is life... therefore, FIRST is full of risks. - Andy Baker [more]
Unread 28-01-2016, 22:16
Txuritan Txuritan is offline
FRC #5612
Txuritan is an unknown quantity at this point
Question Changing rear drive motors max output
Forewarning my team recently switched from Java to LabView so I know little to none of the language.
We currently have a problem in which the two rear motors have a different gear ratio than the front two, the rear has to be set to 75% and the front is keep at 100%, the only way I can thin of fixing this is to rewrite the Talon control VI and I wanted to know if had a better way of fixing it.
It is an arcade drive system using the basic setup given to you as a starter project.
