Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 29-01-2016, 10:15
GavinL GavinL is offline
intensely stares at program
FRC #5726 (Rhumbotz)
Rookie Year: 2016
GavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to behold
Joystick Axis missing (Rookie Team 5726)
Hello, I am Gavin Levis from team 5726. We recently ran into an error when trying to move our robot.
After uploading the robot code from eclipse to the roboRIO and getting all green in the driver station, we tried moving the joystick. However, the robot did not move and in the logs of the driver station it said "Joystick Axis missing".
Unread 29-01-2016, 11:43
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Joystick Axis missing (Rookie Team 5726)
Pull up the USB tab on driverstation and test if moving / pressing everything on your joystick shows up there. If not, check your joystick, cable, USB port, etc. If it does, check the joystick numbers in your robot program.
