Go to Post This just in: moving sideways still a colossal waste of time. - TheOtherGuy [more]
Unread 29-01-2016, 12:15
jlee0119 jlee0119 is offline
FRC #2849 (Ursa Major)
Team Role: Leadership
Rookie Year: 2013
jlee0119 can only hope to improve
Pneumatic system
Hello all,
I'm going to cut straight to the question. Is it legal to have a pneumatic system on the robot(compressor, solenoid, etc...) WITHOUT a air tank in the system?
Thanks
Unread 29-01-2016, 12:23
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
Team Role: Coach
Rookie Year: 2014
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Re: Pneumatic system
Originally Posted by jlee0119 View Post
Hello all,
Thanks
I believe so. Though, the question is "Why would you want system without air tank?"
Unread 29-01-2016, 12:24
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Team Role: Mechanical
Rookie Year: 2016
Type is an unknown quantity at this point
All the diagrams on the game manual appear that you have to have a tank. I'm not sure why you wouldn't want one. You would have very low pressure going to your pneumatic systems, and whenever you used something, you would be using the compressor. That would kill your battery quickly. If you only want to use pneumatics once, it would probably be a better idea to have an off board compressor, and have a tank to store it in.
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Whether or not it's legal, it doesn't make sense. In practically all cases, the solenoids use air faster than the compressor can generate it. Without a tank, the compressor would have to come on every time you actuate something, and run until it makes enough air to do the work.
That said, unless there's something in the rules that says that it is required, it is not.
Unread 29-01-2016, 12:41
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
I see nothing to say it is illegal but you could theoretically store air in the pneumatic tubing between the compressor and the solenoid. That's quite a bit of tubing though.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
