locking pins on the window motors
Robot Rules R30-C what is the " locking pins on the window motors" Can we remove the back cover and pull the factory Shaft out using a snap-ring pliers then install our own custom shaft? Also the "Snow Blower" Motor can do this as well.
Re: locking pins on the window motors
http://wiki.team1640.com/index.php?t...r_Locking_Pins My interpretation is that this would violate R30. Best to ask this on the official Q&A system. |
Long story short, some of these no back clutches use pins. You can take these pins out. Can you make your own output shaft and install it as long as you have the motor apart? No, I don't think so. Runs afoul of the illegal motor mods rules. Sorry. Dr. Joe J. *Back in my GM days, I worked with folks that came out of the Ternstedt division of GM which was a company acquired by GM largely because they had a patent on window lift system that didn't whistle when you went down the road because it had a very clever no back clutch inside. |
We haven't used automotive motors for several years. Many automotive motors also have PTC overload protection in them. We found that using these motors in positioning applications with speed controllers that had a high PWM frequency caused self heating and problems. Did not have problems when used with lower PWM frequency victors. We have no experience with talons and PTC's. The problem was with the Jags.
I wrote a whitepaper on removing locking pins awhile back:
http://www.chiefdelphi.com/media/papers/2685 The modification was made legal years ago (and passed on through the rules since) due to the pins vibrating into a locked position when driven by a Jaguar due to the higher frequency switching used (compared to the old Victor 88x's at least). I am not sure if the newer motor controllers have the same issue although I do know that since Jaguars, as old and discontinued as they are, are still legal, so keeping the mod legal makes sense. Last edited by ratdude747 : 29-01-2016 at 19:04. Reason: re-read my paper's comments, I wasn't correct on something |
