Throttle Trouble
Hi! I am trying to get our shooter to work with two talons by moving the throttle on the Attack 3 joystick upwards. My code looks right, but is not doing anything. Can any of you guys see anything? Any help would be greatly appreciated! Thanks!
![]() Code:
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class RobotTemplate extends SimpleRobot {
* This function is called once each time the robot enters autonomous mode.
Jaguar lTalon,rTalon;
Joystick throttle;
RobotDrive driveTrain;
public void autonomous() {
* This function is called once each time the robot enters operator control.
public void robotInit(){
lTalon=new Jaguar(1);
rTalon=new Jaguar(2);
throttle=new Joystick(0);
driveTrain=new RobotDrive(lTalon,rTalon);
public void operatorControl() {
while(isOperatorControl() &&isEnabled()){
driveTrain.arcadeDrive(throttle.getAxis(Joystick.AxisType.kZ), 0);
* This function is called once each time the robot enters test mode.
Re: Throttle Trouble
Try using throttle.getZ(). Also, since you have a simple robot you should use Code:
#In the operatorControl method lTalon.set(throttle.getZ()) rTalon.set(-throttle.getZ()) |
It still does not seem to be working. Do you see anything else weird? I did all that you said.
Code:
/* the project. */
* directory.
Joystick throttle;
lTalon.set(throttle.getZ());
rTalon.set(-throttle.getZ());
Your class needs to extend SampleRobot, not SimpleRobot. I'm surprised that even compiles as SimpleRobot is not part of the Java API anymore. Give that a try?
