Go to Post Life isn't fair. There's always luck involved. Welcome to the real world. :) - Exla357 [more]
Unread 30-01-2016, 13:18
thomasmcdonald thomasmcdonald is offline
FRC #2587
thomasmcdonald is an unknown quantity at this point
PWM Talon SR Problem
Whenever we try to enable the electrical board (roboRIO) using the driver station, we get the following error from the driver station console:
Code:
ERROR Unhandled exception: java.lang.NullPointerException at
[org.discobots.stronghold.subsystems.DriveTrainSubsystem.tankDriveUnramped(DriveTrainSubsystem.java:133),
org.discobots.stronghold.subsystems.DriveTrainSubsystem.tankDriveRamp(DriveTrainSubsystem.java:76),
org.discobots.stronghold.commands.drive.TankDriveCommand.execute(TankDriveCommand.java:24),
edu.wpi.first.wpilibj.command.Command.run(Command.java:240),
edu.wpi.first.wpilibj.command.Scheduler.run(Scheduler.java:222),
org.discobots.stronghold.Robot.teleopPeriodic(Robot.java:139),
edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:143),
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)]
WARNING: Robots don't quit!
I have tried it with CAN and using the CANTalon class with TalonSRX motor controllers and the code works like a charm and it stays enabled. I am now trying to use the same code, but changing the ports to PWM ports and we are now using TalonSR motor controllers (Which do not have a class in the 2016 libraries). I have changed the motor controller types in the code to Jaguars, Victor, Talon, TalonSRX, and Victor SP, but I am still getting the same error as soon as I enable using the driver station. We also get the same error when there's not anything physically attached to the ports, but they are still referred to in the code.
When I comment out anything referring to the PWM motor controllers, I do not get an error.
Any suggestions on what the problem might be?
Thanks!
