Broke down in the secret passage
It seems like it is possible for a robot to become inoperable in their opponent's secret passage, next to the brattice, such that they are blocking their opponent from acquiring more boulders.
I've been wondering what would happen in this situation. If blue robot is broken down, red robot can come in and try to get to the brattice, contact the blue robot and a tech foul will be assessed to blue. But, then what? Red can back up and hit blue over and over, trying to get push them out of the way. Initially, that might be tech foul after tech foul assessed to blue. But at some point, when the futility of moving blue out of the way is apparent, would that start to become a violation of G11 on red? |
Re: Broke down in the secret passage
Submitted to Q&A.
Well I would look to something that happened to my old team one year. In 2014 we were in a match when one of are alliance partners accidentally pushed a team from the other alliance into out other alliance partner's robot. Initially the rest assigned two tech fouls and then left it for the rest of the match. The tech fouls being assessed for an opposing alliances robot crossing the frame perimeter and potentially causing damage. After the match they ended up removing the fouls because it was not the other alliances fault that they were shoved into another robot. But the real answer to the question is that they would probably give only two fouls and then any continuation of that would probably be covered under G11.
A disabled robot in the other alliance's secret passage can materially affect the other alliance's ability to score.
What if you intentionally e-stopped your robot in the other team's secret passage in order to inhibit their ability to inbound boulders? Seems to me that if you become disabled (or e-stopped) in the other Alliance's Secret Passage, it could be deemed a forfeit of the game. The game would continue for Ranking Points (capture, breaches). Unfortunately, it would still affect the 4th tie breaker: cumulative goal points (5th tie breaker for eliminations). |
This is why I think the question is more complicated than a couple of fouls... Could you imagine if, in Einstein Finals, a robot e-stopped in the opponent's secret passage, accepting 50 points in tech fouls, knowing it would cost them far more than that in scoring? Ouch. It is also brutal to call a forfeit because a robot broke down at an inconvenient moment.... It could be a spot where there is not any good answer at all - and we will all just have to go with whatever the GDC decides and hope it never actually happens. ![]() |
The one exception being: Team lost control of the robot, it ran across the field, hit the wall, and the team e-stopped it. Then, I could see some leniency, but what? It is still keeping the other alliance from scoring. At least a forfeit could stop the alliance from racking up foul points (the disabled robot no longer can receive foul points). Another possibility: The first contact with the disabled robot is the normal penalty (foul). Once that happens, the other alliance is award 5 goal points for every 5 seconds (or portion thereof) remaining in the game. Last edited by rich2202 : 31-01-2016 at 16:49. |
Seems like a good question for a Q&A, or an email to FRCteams more likely. |
Yes, e-stop is not a good idea to do on a regular basis. An e-stop practically invites a reinspection by an RI.
However, if you are one match away from winning Einstein, and ... |
#10
If the explanations come up short, well it's really hard to win with your score reduced to zero by a DQ. |
#11
I hope to be a ref at a couple of events this season, and given my current understanding of the rules this is how I'd call it.
#12
This same issue seems to happen if a robot is disabled in their own courtyard during the last 20 seconds. Touching them is easier than scoring points. I think that further rules clarification will show that this is considered unGP but we will see...
#13
From Q&A:
A. We will not rule definitively on hypothetical scenarios in this forum as many factors may play into rulings in individual situations. Generally a Team will not be called for G11 (attempting to draw a foul) if they are, in the judgement of the Referee, attempting to play the game, however futilely. There is no exemption from penalties for ROBOTS which have become immobile or DISABLED. It sounds to me like, should this happen, a robot should try to continuously move the "dead" robot from the secret passage.... |
#14
I can tell you a few years back during Ultimate Ascent an alliance member's robot went dead after getting hit and just coasted into the opponents protected box. Then for the rest of the game as everyone came in for Frisbees they would tap that robot while in motion and gain some free foul points since he was "in the way".
Those are the rules and the risks. -Bernie |
#15
I think people are forgetting that you can enter a boulder in the brattice (upper opening) as well. I find it hard to believe all of the boulders would end up on the field without some in a playable location.
So in my opinion, disabling the robot in the secret passage would only result in a lot of fouls against your team and while slowing the other team down would still result in your loss. |
