Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 30-01-2016, 14:03
bunnmeister1168 bunnmeister1168 is offline
FRC #1168
bunnmeister1168 is an unknown quantity at this point
Trouble with the new radio
Using the new config tool changes the settings as advertised, but when attempting to connect to the roboRIO using the driver station and the radio we have intermittent connection at best (yes, firewall is disabled).
A quick description of the situation:
Pinging the radio from the DS does not work.
Pinging the roboRIO from the DS does not work.
Pinging the radio from the roborio does work.
Ringing the DS from the roborio does work.
What setting did we overlook?
Unread 30-01-2016, 14:57
shadow747 shadow747 is offline
AKA: Brian
FRC #2930 (sonic squirrels)
Rookie Year: 2012
shadow747 is an unknown quantity at this point
Re: Trouble with the new radio
did you try tuning it on and off again? did you look at the manual? and could there be a wi-fi obstructing yours?
Unread 01-02-2016, 15:24
FRC #1168
I turned it on and off countless times and I even re-flashed the modem countless times. I have followed the manual to a T. Considering we are in a basement, we're pretty much the only wifi signal around.
Unread 01-02-2016, 15:37
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Reflash the roborio to make sure it has the right team number and the right firmware version.
Reconfigure the Radio to make sure it has the right team number
Set the IP settings on the wifi adapter to discover the IP address automatically.
Make sure the Driver Station has the right team number.
Try to connect. If it does not, try to ping the roborio from the DS.
If at any point you can ping the roborio from the DS laptop, then check to make sure you have the right version of the DS loaded.
If you can't ping the roborio ...
Set the IP settings on the Ethernet adapter (hard wire) of the Driver Station Laptop to discover the IP address automatically.
Plug the laptop into one port of the radio, and the roborio into the other. Disable the wifi adapter on your DS laptop.
Try to connect. If it does not, try to ping the roborio from the DS. If you can't ping the roborio ...
Set the IP settings on the Ethernet adapter (hard wire) of the Driver Station Laptop to 10.TE.AM.101
Plug the ethernet wire directly from the DS Laptop to the Roborio (bypass the radio).
Try to connect. If it does not, try to ping the roborio from the DS. If you can't ping the roborio repeat with a new driver station. If that doesn't work, try a new roborio.
Unread 01-02-2016, 16:12
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The interesting one is the last one. The others all make sense if there's an issue with the Wi-Fi connection - the DS can't get to anything, the roboRIO can get to the radio because that's a wired connection. But the last one should involve the Wi-Fi as well... What's your setup for that one? Using a development computer over USB to ssh into the roboRIO to ping the driver station that's only connected over WiFi?
I would recommend starting from scratch. Re flash the router. Check the ipv6 and ipv7 setting a for your laptops Wi-Fi and get that all set up properly. Restart everything. Ensure the laptop is connecting to the correct Wi-Fi network (and that the network is absent when the robot is turned off!). Focus everything on getting comma between the radio and the laptop first, as that's the hardest, then add in the Ethernet connection to the roboRIO - wired connections usually work really easily.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
