Go to Post If time only weren't a factor, everything would be done. - Schnabel [more]
Unread 30-01-2016, 14:30
Sav01027's Avatar
Sav01027 Sav01027 is offline
AKA: Sav Sidorov
FRC #5897 (Apex Robotics)
Team Role: Leadership
Rookie Year: 2015
Sav01027 is an unknown quantity at this point
Question about "Withholding Allowance"
Reading over the rules, we couldn't find a clear statement on this: Can electronics be considered part of the "Withholding Allowance" that can be added onto the robot during competitions? We're building a practice robot and we'd prefer not to pay double for electronics if it can be avoided.
Has anyone looked into this before?
Thanks.
Sav Sidorov
Team 4334: ATA (2015)
Team 5897: APEX Robotics (2016 - )
Unread 30-01-2016, 14:34
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: Question about "Withholding Allowance"
Anything can be part of the Withholding Allowance.
Note: You do not have to include COTS parts that have not been modified.
For example, if you are using a Raspberry Pi, the Pi itself is COTS and can be excluded. But, if you modify it (custom mount with other electronics), then that would be Fabricated, and have to be included.
Unread 30-01-2016, 23:21
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Also keep in mind that two COTS parts attached to each other count as an assembly and against your withholding allowance. This counts for electronics too. You could keep a significant amount of parts off your robot for ship day if you disassemble it all down to cots parts and reassemble it at the event, but I wouldn't recommend it.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2016)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 31-01-2016, 05:55
Sav01027's Avatar
AKA: Sav Sidorov
Rookie Year: 2015
Okay, thanks. The whole "Fabricated parts" threw us off, although I can almost certainly recall teams moving their electronics in past years.
Sav Sidorov
Unread 31-01-2016, 10:08
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Originally Posted by Game Manual, 4.1, page 4 between the blue boxes, and repeated in the glossary
A FABRCATED ITEM is any COMPONENT or MECHANISM that has been altered, built, cast, constructed, concocted, created, cut, heat treated, machined, manufactured, modified, painted, produced, surface coated, or conjured partially or completely into the final form in which it will be used on the ROBOT.
If you do much more than open the box/bag/shrink wrap and inspect it, it's probably a fabricated item.
See also the first blue box of 4.1 for some case studies, and of course R18, which describes the withholding allowance and its exemptions. (Warning: there are fewer exemptions to the withholding allowance rules than in the robot fabrication rules.)
