"Hooked" on this thread
Hello from Team 4490!
We are using a ladder-like mechanism to pull ourselves up the tower and we have steel hooks atop this ladder. If anyone has any hooks which they have used or hook ideas for us to use, it would be greatly appreciated as we are looking for a new design that will not bend as these do. The robot appears too heavy for the hooks. When I say hook ideas, I am referring to designs or references to websites/forums where there are examples of different hooks to use. Thank you again for your help! Last edited by tiernan12992 : 30-01-2016 at 15:26. Reason: Revision of my previous wording. |
Re: "Hooked" on this thread
I managed to find a set of hooks that would go perfect honestly. So... I suppose that this thread can now just be used for general discussion of hooks and things of the like?
Just do whatever it is that you do. http://www.amazon.com/gp/product/B00...A2RNBXAVQ4OOHG |
What is the weight capacity for those? If your robot is 140lb (120 + battery and bumpers) you might bend them.
I guess that is a start. |
This is the hook we used to lift our robot up the steel pipe tower in Rebound Rumble:
https://grabcad.com/library/first-ro...-rumble-hook-1 The model doesn't show the screws used to hold the plates together. It was made from 6061 aluminum using a bandsaw, grinder and hand tools. The hook worked fine. A similar hook should work this year. |
We made excellent hooks on our 2010 robot by cutting them out of 1/4" aluminum plate. A bit of a pain, but with adequate stock you can do a lot of playing around to make sure they're exactly how you want them.
We made a single hook out of 1/8 aluminum and it holds my weight with minor deformation (175 pounds)
We were also concerned about whether or not .125" would bite into the bar and cause damage that would Red Card a robot. |
If fifteen years of FIRST has taught me anything, it's that if it looks like it might be a problem, you at least need to consider it.
#11
I cannot argue with that!
#12
We're planning on using either one or two of these:
http://www.homedepot.com/p/Tornado-4...8034/202639947 I think the 40 lb. limit is for the wall anchor not the hook itself. So far we've tested a single hook to 100 lb. without issue. |
