Extension
Does the extension perimeter of 15 inches have any bearing on the maximum extension a robot has should it want to reach the high bar?
Re: Extension
No problem if you are only extending vertically from your ROBOT.
But if your ROBOT tips so that the FRAME PERIMETER is no longer parallel to the floor, it would be at a large risk of violating G18. |
Re: Extension
Rule G17 states the following:
Re: Extension
Better example, imagine sitting in a box you are allowed to reach up as high as you want straight up. The second you stick your hand 16 inches out of the box you get slapped on the wrist and told "no" |
Re: Extension
Re: Extension
Re: Extension
Here's one. https://plus.google.com/117322302265...2 65076381504 |
Re: Extension
Re: Extension
You are in a box, extending 15" from your Frame Perimeter, height 4'6". At 20 seconds left in the match, the lid is taken off. The box orients with your robot (in relation to the robot's "flat floor" position). If at any point you go through the walls or lid of the box, the penalty flags fly. |
#10
Re: Extension
