Go to Post I'd be upset if someone threw away my robotics shirts. Because then I'd have no shirts. - evulish [more]
Unread 30-01-2016, 19:16
Team5860-Alex Team5860-Alex is offline
FRC #5860
Team5860-Alex is an unknown quantity at this point
4 motor joystick direction error
We have used the default code for a 4 motor system and changed the left side to false inverted and the right side to true inverted. So our robot moves left and right correctly but it is going backwards when we push forward on our controls, is there a way to invert this y-axis problem?
Unread 30-01-2016, 19:31
rohinb rohinb is offline
FRC #3482
rohinb is an unknown quantity at this point
Re: 4 motor joystick direction error
In my experience, if you are using tank/arcade drive, you should either have all motors inverted or none of them inverted. If this doesn't fix it, you should have your electrical team check to see if the wiring is uniform.
Unread 31-01-2016, 08:55
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
You should have one side inverted, as it is oriented in the opposite direction, so that is correct. It sounds like you might have your left and right tracks swapped; that would produce correct "rotate in place" behavior but reversed "straight drive" behavior, which sounds like what you're describing.
