Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Unread 30-01-2016, 20:51
carpedav000's Avatar
carpedav000 carpedav000 is online now
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
Team Role: Mechanical
Rookie Year: 2010
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Anti Cable Slip?
We are using a Choo Choo mechanism to pull back steel cable for our shooter this year and we are wondering how other teams have prevented their cables from slipping. Any help would be much appreciated.
It isn't shiny enough.
Unread 30-01-2016, 20:59
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Re: Anti Cable Slip?
You could look into sailing line and tying a bowline at each end.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 31-01-2016, 09:01
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
You could drill a hole through a rotating bolt, pass the cable through and secure with crimps or clamps, either a single block behind the bolt, or loop the bitter end back around for a standard loop crimp.
Another possibility would be to crimp a loop snugly around a pulley or other sheave (e.g. two shaft collars with a gap between them).
Unread 01-02-2016, 20:58
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Rookie Year: 2013
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
I believe you are referring to a way to make sure you don't slip back down the rope after you climb. if you are using rope (I recommend military 550 chord , also known as Para-chord) then there are a few options available.
1) a knot, the types of knots you want are either a prussic knot or a taught-line hitch. These are both knots that can slide along rope but lock in place under a load.
2) a repell and belay system, this is used a lot to get people down from high places SLOWLY, but the system provides a way to stop the decent simply by changing the angle of the rope into the belay system.
3) commercialy available rock climbing equipment can do something like this.
4) a ratchet system. you spool that you attach your rope to cannot be back driven if you put a ratchet system. most store bought winches has a locking ratchet on them
