Go to Post i will not post here...i will not post here....well...okay, yes I will - David66 [more]
Unread 31-01-2016, 10:20
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
Rookie Year: 2011
java4first is an unknown quantity at this point
Help w/ WPILib Preferences
Hi -
I had something that worked for this last year, and things in WPILib have changed, and I'm having problems with the same approach this year.
The name of the file stored on the roboRIO in the lvuser home directory has changed (now networktables.ini), the header or 1st line is different, and the format of the properties themselves are different. I got through all that.
So that I don't have to use the SmartDashboard to get the properties loaded, we had a script that used pscp (from Putty) to download a copy of the file on command from the development laptop to the roboRIO.
The problem is that WPILib now throws a complaint about the format of the header, and refuses to process the rest of the file. If I do a diff of the file as copied from my Windows development laptop and the one written by the pscp copy, every line is different, but there is no discernible difference ... so I'm thinking maybe it is the way the end of line is handled on Windows vs. Linux?
WARNING: /home/lvuser/networktables.ini:1:header line mismatch, ignorning rest of file (Dispatcher.cpp:71)
WARNING: When reading initial persistent values from '/home/lvuser/networktables.ini'Dispatcher.cpp:69)[/indent]
It used to work without problems ... And I can live with running the SmartDashboard every time they change just to update the file, but it's kind of awkward and inconvenient. Does anyone from WPILib development know if there is some other problem I can fix on my end?
Thanks in advance!
Stu
