Go to Post Many students I have met will insist that nothing is better than FIRST robotics. And most people would agree that a ham sandwich is better than nothing. So does it logically follow that a ham sandwich is better than FIRST robotics? - tsaksa [more]
Unread 31-01-2016, 16:33
JagCode's Avatar
JagCode JagCode is offline
Bring Your "B" Game
AKA: Noah
FRC #2929 (JagBots)
Rookie Year: 2014
JagCode will become famous soon enough
pic: 2929's Forklift + Climber, almost operational
Unread 31-01-2016, 20:47
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Re: pic: 2929's Forklift + Climber, almost operational
I hope you've done the math on the volume of air those cylinders you've chosen will need to extend and then retract.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 31-01-2016, 22:01
JagCode's Avatar
Bring Your "B" Game
AKA: Noah
FRC #2929 (JagBots)
Rookie Year: 2014
We have. We debated over what ways we can deploy a winch, but in the end we decided to re-purpose the air cylinders we already had as the deploying mechanism.
They only extend, we'll be using the rest of the forklift to lift the bot (more importantly, the bumpers) over the line.
Unread 01-02-2016, 01:48
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Did this early on.
As it happens, if you use 1.5''-bore, 2'-stroke cylinders and run them out at 30PSI and in at 60PSI, you're more than covered with two black clippard tanks.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 01-02-2016, 02:43
MichaelBick MichaelBick is online now
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Originally Posted by Oblarg View Post
Did this early on.
PSI drops as you use your tanks. So at some point you won't get quite the full force of your actuators.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
