Go to Post remember to turn the robot on. - Laura_587 [more]
Unread 31-01-2016, 19:57
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
pic: 4301 Current Progress
Unread 31-01-2016, 19:59
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: pic: 4301 Current Progress
I hope you will never put significant force on those omniwheels at the end, or the shaft might bend. Are you sure that it will be absolutely impossible for something to hit the omniwheels on the outside? Other robots crashing into it comes to mind.
Unread 31-01-2016, 20:07
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
Rookie Year: 2010
fargus111111111 is on a distinguished road
How are you going to get the battery out? It seems to be trapped by the electronics and that motor.
I didn't break it... this time.
Unread 31-01-2016, 20:58
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Rookie Year: 2011
We were only planning on extending the omni wheel bar while we were in the protected zone of the outer works, but we will definitely consider reinforcing the shaft.
The second level of the electronics panel slides toward the front of the robot to let the battery in. This wasn't included in the CAD model for simplicity's sake.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 31-01-2016, 21:07
KohKohPuffs KohKohPuffs is offline
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Team Role: CAD
Rookie Year: 2013
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
Instead of having one arm in the middle, try using two arms to support the shaft on both ends. This might be a bit more weight, but adds more structural support to the omni shaft. It may also move the motor gearbox out of the way of the battery
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 31-01-2016, 21:09
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Yes, please reinforce it. The rules may be in place, but they can be broken. The only thing to protect your design is the design itself. No penalty in any way shape or form for any game will guarantee protection to your mechanisms. Only your design does.
Other than that, your robot seems like it could be a valuable asset to any alliance. I was just talking to some students about strategies today and one of the designs we mentioned that we would want on an alliance looks very much like yours.
Unread 31-01-2016, 21:40
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
What is that omni assembly doing anyway?
Unread 31-01-2016, 21:53
Drew_trak's Avatar
Drew_trak Drew_trak is offline
AKA: Drew Petrak
FRC #0599 (Robodox)
Team Role: Mechanical
Rookie Year: 2014
Drew_trak is an unknown quantity at this point
Are you able to shoot in the high goal? Can you travel
through all the obstacles?
Unread 31-01-2016, 22:01
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Rookie Year: 2011
The omni bar is for lowering the cheval de frise and raising the portcullis. The arm it's attached to is also meant to open the sally port and get the drawbridge down to the floor after we get it most of the way down with another as yet unfinished mechanism.
Originally Posted by Drew_trak View Post
Are you able to shoot in the high goal? Can you travel through all the obstacles?
We designed to be a ferry bot / low goal scorer. It is intended to cross the category A and C defenses in addition to the low bar. It has the potential to cross some of the others if the omni bar is used, but that is not something we specifically designed for. It should be able to score into the low goal on its own or deliver boulders to a high goal shooter if the strategy necessitates that.
Unread 31-01-2016, 23:06
jamesmcip jamesmcip is offline
It's fine, don't worry about it
AKA: James Cipolletti
FRC #4908 (Dragons)
Team Role: CAD
Rookie Year: 2014
jamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of light
What CAD software does your team use? That render looks absolutely fantastic.
Unread 31-01-2016, 23:53
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Yes, please reinforce your omni-wheel arm. No rule will prevent your driver from accidentally banging this into field structures and the guardrails. You won't even get the "satisfaction" of being granted penalty points if this happens.
Please reconsider this strategy for installing your battery behind a moving panel. Based on my experience from my day job, moving panels should only be a last resort. Doing something like turning your battery 90 degrees and moving it up against one side (taking the place of two of your motor controllers) will offset your CG a bit but it should not affect the performance of your robot to a significant degree. You could also mount pairs of the motor controllers on (new) vertical panels roughly above the motors and move the battery "forward", out from under the motor for the omni-wheel bar.
Where will your PDP, VRM and router be installed? It is easier to pass inspection if those are visible without a lot of moving panels around. Troubleshooting will also be much easier. My guess is that you should have two more motor controllers than what are visible (for your omin-wheel arm actuator and one for your intake rollers).
Don't insist on the layout of the components being symmetrical. The electrons won't care in this type of application.
Best of luck in Lubbock. Hope you make it to Lone Star some time.
Unread 01-02-2016, 12:38
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
How about what do you have securing that battery besides the sliding electrical panel? Remember that this is likely to be violent game this year with lots of heavy defense. If your battery isn't well secured, it's going to start wandering around inside your robot running into things, which is never good. Also, remember there may be significant vertical forces as well as horizontal forces acting on the battery.
Unread 01-02-2016, 18:51
Mentor
FRC #2587
Rookie Year: 2011
Your battery weighs about 13 lb. Think of an unsecured battery as a 12 lb. sledgehammer bouncing around inside your robot.
Unread 01-02-2016, 19:57
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Rookie Year: 2011
Thanks! We're using Inventor 2016.
We will definitely fix this soon.
The PDP, VRM, and 4 more Jaguars are located on a second panel underneath this one. They are all visible through the top panel for diagnostic purposes. We will try to rearrange to better fit the battery.
The battery was going to be secured by wrapping two industrial strength velcro straps around it in a cross formation and through slots in the plywood panel at the bottom.
Thank you all for the feedback! We greatly appreciate it!
  #15   Spotlight this post!
Unread 02-02-2016, 22:16
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
I think you guys did a terrific job for your first CAD robot .....
Keep up the great work....
Now you just have to fabricate it!!
hope to see you on the field!!!
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
