Go to Post Everybody "cares about the robots" - otherwise we'd be doing science fairs. - Taylor [more]
Unread 31-01-2016, 21:50
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
Rookie Year: 2011
TimTheGreat will become famous soon enoughTimTheGreat will become famous soon enough
"Ticks" per revolutin Absolute Encoder
Does anyone know the 'ticks'/counts per revolution of
http://www.andymark.com/product-p/am-2899.htm
This is the number that CanTalon.getAnalogInPosition() reads
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 31-01-2016, 21:57
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: "Ticks" per revolutin Absolute Encoder
See section 16.11 or 17.2 of the Talon SRX Software Reference Manual.
Unread 31-01-2016, 22:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Tim,
Going to the downloads tab on the AM page you linked, then looking at the datasheet, I found that it supports several options:
  • 10-bit Analog output - 2.6 kHz sampling rate
  • 10-bit PWM output - 1024 positions per revolution, 1 kHz
  • 12-bit PWM output - 4096 positions per revolution, 250 Hz
It looks like it's somehow program selectable among these modes.
Unread 31-01-2016, 23:10
ArchdukeTim
Rookie Year: 2011
So I was looking at these, but they don't seem to match what the robot was doing.
I printed out motor.getAnalogInPosition() and I got discrete numbers that kept increasing like a standard encoder.
Unread 01-02-2016, 07:37
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
I'm thinking a software bug in your code is involved.
None of the three versions of that encoder produce "ticks" because of rotating.
Double-check that you are invoking a suitable analog read function, and thatsome other part of your code isn't summing the values you read.
The encoder output definitely is not the sort of signal that typically would get connected to an interrupt or other hw input port so that pulses could be counted. Instead its amplitude or duration should be measured (either Volts or Seconds), depending on which version of the encoder you are using.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
