Go to Post But altering register values via bitwise operations in nested ternary commands is so much fun! - artdutra04 [more]
Unread 02-01-2016, 04:29 AM
Turing'sEgo Turing'sEgo is offline
Rookie Year: 2010
Turing'sEgo can only hope to improve
Need help fine tuning vision algorithm
I want to get the outer 4 corners of the targets, but all the methods I've tried are not as accurate as I'd like. Anyone have any ideas as to how I can do that? Image of a few of my attempts
Unread 02-01-2016, 06:48 AM
Re: Need help fine tuning vision algorithm
It looks to me like you have the outer edges. Have you tried to solve for the line intersections?
Greg McKaskle
Unread 02-01-2016, 07:32 AM
lphung lphung is offline
FRC #5994
lphung is an unknown quantity at this point
Hi,
I am not sure what is the vision library you are using. If you are using OpenCV, I could suggest using the function: convexHull.
http://docs.opencv.org/2.4/doc/tutor...hull/hull.html
Unread 02-01-2016, 12:22 PM
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Nice work!
For more accuracy you might try using the Find Edge function (in LabView it's under the Machine Vision palette). Once you have a rough idea of the size and location of the targets, Find Edges can do great things. I'm sure OpenCV can do something similar.
Can you post your code?
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
