Go to Post IRI seeks to invite the very best robots to play the FIRST game, achieving the highest level of play, while keeping in place the FIRST atmosphere. - Nathan Streeter [more]
Unread 01-02-2016, 15:25
jbernardis jbernardis is offline
FRC #1403
jbernardis is an unknown quantity at this point
Encoder resolution on fast turning shafts
We are planning on using an encoder on our shooter design to determine actual RPMs. Do I need to worry about interrupt load on the processor if I have the combination of a fast (~5000RPM) shaft and a high resolution encoder. I was thinking of trying to get a reduction gear in there to reduce the RPM and then go with a low res (32 ticks/rev) encoder.
Are the considerations the same if I connect the encoder to the Talon SRX instead of the Rio??
