Go to Post The best teams have students who genuinely enjoy scouting and the alliance selection process. - Jay O'Donnell [more]
Unread 01-02-2016, 18:31
LFRobotics's Avatar
LFRobotics LFRobotics is offline
FRC #4623
LFRobotics is on a distinguished road
Pnuematics Toggle Code Issue
Okay so when I press the button associated with the toggleSolenoid command the cylinder occasionally actually toggles back and forth at the touch of the button - but more often than not it just spazzes back and forth repeatedly.
What is wrong??
Pnuematics Subsystem:
Code:
package org.usfirst.frc.team4623.robot.subsystems;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Pnuematics extends Subsystem {
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
	Compressor comp = new Compressor(0);
       DoubleSolenoid ds1 = new DoubleSolenoid(0, 1);
	public Pnuematics() {
		comp.setClosedLoopControl(true);
    public void initDefaultCommand() {
        // Set the default command for a subsystem here.
        //setDefaultCommand(new MySpecialCommand());
    public void toggleSolenoid() {
       if(ds1.get() == DoubleSolenoid.Value.kForward) {
    	   ds1.set(DoubleSolenoid.Value.kReverse);
       else {
    	   ds1.set(DoubleSolenoid.Value.kForward);
    public void stop1() {
    	ds1.set(DoubleSolenoid.Value.kOff);
toggleSolenoid Command:
Code:
package org.usfirst.frc.team4623.robot.commands;
import org.usfirst.frc.team4623.robot.Robot;
import edu.wpi.first.wpilibj.command.Command;
public class toggleSolenoid extends Command {
    public toggleSolenoid() {
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
    	requires(Robot.pnue);
    // Called just before this Command runs the first time
    protected void initialize() {
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
    	Robot.pnue.toggleSolenoid();
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        return isTimedOut();
    // Called once after isFinished returns true
    protected void end() {
    	Robot.pnue.stop1();
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
    	end();
Connection between Button and Command:
Code:
toggleSolenoid.whileActive(new toggleSolenoid());
Thanks so much for the help!
Unread 01-02-2016, 18:46
TGurlik's Avatar
TGurlik TGurlik is offline
Scouting Co-Leader
AKA: Travis Gurlik
FRC #0706 (Cyberhawks)
Team Role: Scout
Rookie Year: 2014
TGurlik is an unknown quantity at this point
Re: Pnuematics Toggle Code Issue
My team has just switched over to Java from C++ this year, so I'm a little unsure of myself, but I think I know what your issue is. Using whileActive to toggle your solenoid will result in the toggleSolenoid() function running repeatedly as long as the button is held (assuming I'm understanding this right). If there's a function you can use that will only run once when the button is pressed instead of whileActive, that would be best. Otherwise, you can look into using a timer to run the function at most once every half second or so, which would keep it from freaking out.
FRC Team #706 CYBERHAWKS:
2014 - Programmer:
Lake Superior - Finalist (with teams 3313 and 3883) and Industrial Design Award
Wisconsin - Finalist (with teams 3018 and 1259) and Quality Award
2015 - Programmer:
Wisconsin - Quality Award
Queen City - Creativity Award
Tesla Division
2015-2017 - Programming Mentor for FTC Team #9956 The Knack
2016 - Scouting Co-Leader:
Buckeye - Finalist (with teams 27, 379, and 1014)
Wisconsin - Finalist (with teams 5903 and 537), Excellence in Engineering Award, and Industrial Safety Award
2016-2017 - ???
Unread 01-02-2016, 20:39
Joe Derrick's Avatar
Joe Derrick Joe Derrick is offline
Mentor - Programming
FRC #0319
Rookie Year: 2011
Joe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of light
Hey there, try adding or modifying your subsystem to this
Code:
public boolean toggle;
    public void solenoidIn() {
	toggle = true;
    public void solenoidOut(){
toggle = false;
these are two methods which when called will set the solenoid in a direction then flip the state of the boolean
then your Command to this
Code:
	if (Robot.pnue.toggle == true)
    	Robot.pnue.solenoidOut();
    	else if(Robot.pnue.toggle == false){
    	Robot.pnue.solenoidIn();
return true;
    	end();
since solenoids retain their "state" when switched, they do not need to be told continuously what do do. they are set to forward or reverse one time in the "initialize" part of the command depending on the state of the boolean. Then the command finishes immediately.
the OI should be
Code:
toggleSolenoid.whenPressed(new toggleSolenoid());
Best of luck, hope this helps. Once mastered, command based is the way to go!
Also there may be other ways to acheive a "toggle" but this has worked for us in the past. I did see a "toggle option" in the OI this year but have yet to test it.
2010-2017 Mentor Team 319
2012 - Rockwell Automation Award Winner
2014 - Xerox Creativity in Engineering Winner, Archimedes Division
2015 - Rockwell Automation and Gracious Proffesionalism Winner, Tesla Division
2016 - North Shore and UNH District Event Winner, Carson Division
http://www.frc319.com
Unread 02-02-2016, 16:10
LFRobotics's Avatar
FRC #4623
Okay using your code I got it to work - thanks so much!
