Denso Window Motor
So, I took a look at the window motor we got in the KoP this year, and it's a little different from what we've got in the past. Has anyone found a reliable way to attach to the output (like the hubs we had for the old ones)? What about mounting it? There are some apparent mounting holes, but they don't go all the way through, and tapping them didn't really seem to work out so well.
Re: Denso Window Motor
Honestly, I looked at those motors and sighed. Then tossed them back in the tote and that's where they are still.
Kind of a shame really, I'm not sure how good the motors themselves are? But they sure don't seem like they want to back drive
Of course not...they're window motors. You wouldn't want someone to be able to slide down your car window, would you?
Just wishing they had an output shaft that was a bit more user friendly.
Sounds like a good application of a 3D printer. Print some hubs?
Doug Last edited by dchartley : 03-02-2016 at 12:57. |
#10
Not knowing what and how you plan to use this for limits responses.
We 3d print many adapters for the Denso motors. They work quite well depending on loading. If there is going to be shock loads you would need to use metal and bearings with supports so the transmission doesn't take the abuse. Depending on output needed you can.. CAD an adapter and have it 3D printed. - Many local teams can help with this, even us if you need. Take a hex axel and mill it down, cut some groves on either side of the output for an "E" clip. Or drill out the end and tap it for a retaining bolt and washer. From a quick look at this motor in CAD the opening is .238 which is roughly 15/64th.. Which is one step down from 1/4". If you take a 1/4" hex shaft it will require very minimal grinding / milling to get it square enough to fit. Then use an adapter to get to the require output size. Post a little more what you plan to actuate with this motor. 1/2" hex, sprocket, pulley, etc. We have used Denso motors every year since our rookie year. This might be our first year NOT needing to use one. We do have lots of experience using these window motors and would love to help you integrate them into your design. Good luck, Aloha! |
#11
In my opinion for a heavy load you are better off making your own axle out of some metal stock. Especially if you are considering hanging your robot from this motor. It is meant to hold up a car window roughly 20 lbs, depending on the car. I think making a 1/4" axle with a 1/4" to 1/2" hex adapter would be a good solution. Also you will be better off putting a bearing on both sides of the axel. Such as the 1/4" hex axle comes out of the motor. Then the hex adapter, support structure with a 1/2" hex bearing, rest of the 1/2" axle connected to whatever, then the other support and 1/2" hex bearing. Hope this made sense, Looking forward to some pictures of this mechanism. Good luck with this, keep us informed. Aloha! |
#13
You can print this if you have a good 3D printer
http://www.thingiverse.com/thing:388315 |
#14
