Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 02-02-2016, 09:20
acrilex acrilex is offline
AKA: Alexandre Croteau
FRC #5179 (Sénateurs)
Rookie Year: 2014
acrilex is an unknown quantity at this point
Finite state machine problem
Hello,
I have a problem... One of our team's mentor decided that we would code our robot on a finite state machine format. Our code is available here. However, we can't get any FSM working. Right now, we tested a FSM in BallControl.java. It is initialized in out teleop.java command, and the buttons and motors values are updated in the execute() function. The problem is that, when we enable teleop, it goes straight to state 1 (!). No buttons nor the limitSwitch can change this state. If we disable teleop and re-enable it, it stucks in state 0 (waiting), no buttons can change this state (!). Can someone please help us to correct this problem?
Alexandre Croteau (acrilex)
Head coder,
Team 5179 Sénateurs
