Go to Post Yes, good job being calm and asking about the validity of a rumor before fanning the flames and assuming the conspiracy must be true. - Greg McKaskle [more]
Unread 02-02-2016, 14:26
kingca kingca is offline
FRC #0108 (SigmaC@ts)
Rookie Year: 2015
kingca is an unknown quantity at this point
JoyStick
We are having a problem with the joystick update values when ever we move the joystick the values do not update at all. We have followed all the steps on the wpilib websites and still cannot solve the problem. We have one last option we want to try but in the time waiting we want to see if other teams have had our same problems. If you have not experienced this problem can you please tell us what you are doing so we can try to solve our problem.
From Team 108 the SigmaC@ts
Unread 02-02-2016, 16:19
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Re: JoyStick
Can you see them work in the driver's station on the "USB devices" tab?Its the second one from the bottom on the left.
There is another place in the Windows OS where you can see if the joystick is working: Control Panel > View Devices and Printers > Right Click on your controller, select game controller settings, then select
properties again.
If it doesn't work in both those places, then the driver is not installing for it, the joystick is bad, or you have a bad USB port. Try another USB port. If you have it plugged into a hub, try plugging it directly into the computer.
Brian K
Team 1225 Robotics Mentor
Unread 03-02-2016, 23:41
boxerbaby30's Avatar
boxerbaby30 boxerbaby30 is offline
Future Computer Science Mogul
AKA: Andrew Gordon
FRC #0108 (Sigmac@ts)
Rookie Year: 2013
boxerbaby30 is an unknown quantity at this point
Re: JoyStick
All the joystick values are updating on the DS but the joystick output value are not working in the code. We even added a printf statement to see what the code was outputting. It always stayed with whatever value the joystick has when the roboRio or robot code is reset.
2014 Peachtree Winner (Thanks to 1683 & 2283)
2015 Peachtree Winner (Thanks to 4188 & 343)
Unread 05-02-2016, 16:04
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: JoyStick
This would be easier to troubleshoot if you posted your code.
