Go to Post First and foremost, teach which end is the hot one on a soldering iron. - Al Skierkiewicz [more]
Unread 02-02-2016, 16:45
Brian564 Brian564 is offline
FRC #0564
Brian564 is an unknown quantity at this point
USB Camera Troubles
Hey, I'm a programmer on team 564 for Longwood high school, I was wondering if you could help us solve our issues with the Java Smart Dashboard 2.0.
We're able to use our USB camera plugged into the roboRIO on the default LabView dashboard, but we're unable to get it to work with the camera widget on the Smart Dashboard 2.0. We're not sure how MJPEG streaming works, or what the path to the .mjpeg is supposed to be. We have an IP camera but we're not sure how to put that into the Smart Dashboard either.
Also our saved dashboard layouts seem to corrupt after computer restart. Trying to load a previous Smart Dash save file doesn't do anything, we have to rebuild it. Loading dashboards only works for .dash files that were created after the last boot.
Unread 03-02-2016, 07:39
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: USB Camera Troubles
Sfx (2.0) doesn't have USB camera support by default for some reason. Our team decompiled smartdashboard and used the USBCamera code from there to build a plugin for sfx.
