Go to Post Stupid rules are still rules. They're not meant to be broken, they're meant to be changed. - Alan Anderson [more]
Unread 02-02-2016, 18:35
Team5860-Alex Team5860-Alex is offline
FRC #5860
Team5860-Alex is an unknown quantity at this point
Need help, talon srx labview coding
the drive train is working however the other motors are not even though we referred to the software manual to make the code and don't know the issue. We dont see anybody else experiencing this issue so if anybody could help.
https://www.dropbox.com/sh/quwlwd2kl...hpl8WvUEa?dl=0
Unread 02-02-2016, 19:14
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Need help, talon srx labview coding
Hi Alex. Welcome to Chief Delphi.
Maybe start with what you are observing versus what you are expecting?
Unread 02-02-2016, 19:24
FRC #5860
We are getting blinking orange, no response, on any motor controllers other than the working drivetrain (blinks green/red with throttle)
Unread 03-02-2016, 11:47
Nirnaeth Nirnaeth is offline
Coach/Mentor
AKA: Michael Liang
FRC #6367 (The Brooke High ElectroLights)
Nirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud ofNirnaeth has much to be proud of
Hello,
Can you answer these questions first?
1. Are your Talon SRX motor controllers set up in CAN mode (each motor controller serially hooked up) or with PWM (each motor controller connecting directly to the roboRio?
2. Do you have the other motors opened up in Begin.vi?
3. What buttons do you have mapped to each of the other motors?
4. Can you take a screenshot of each of the following: Begin.vi, Teleop.vi, and Finish.vi? (This is purely selfish, as I don't currently have Labview to be able to open your block diagram.)
Lead Mentor - Team 6367 - The Brooke High ElectroLights
Former Mentor - Team 5969 - The English Skunkworks
Former Mentor - Team 1754 - The Excel Nitro Knights
Unread 03-02-2016, 13:36
FRC #5860
Originally Posted by Nirnaeth View Post
Hello,
1) CAN
2)We have 8 total mcs wired but cant even get that single motor code to work
3) we dont have any motors mapped to buttons but another joystick instead
4) https://www.dropbox.com/sh/xkx3czbkt...3DNXCvWsa?dl=0
Unread 03-02-2016, 13:56
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
Team Role: Coach
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Without confirming with our programmers, I believe your motor constants are not correct in Begin.vi. Instead of '0', '1', ours read 'PWM0', 'PWM1' etc. from a drop-down list-box constant. The number corresponds to the CAN ID of the talons. Best way I found to do a constant is to right-click the input terminal of the vi and select 'create constant'. That way you're ensured that the correct type is created.
Unread 03-02-2016, 14:04
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
This is correct if you are using PWM, but for CAN Talons, the constants will be just a number.
Originally Posted by Team5860-Alex View Post
1) CAN
Have you gone through and given each Talon a unique ID through the RoboRIO webpage? They may all still have the default ID set. From what I can tell, your code looks good and should do what you want it to.
I'm right 90% of the time, so why worry about the other 3%?
Unread 03-02-2016, 14:42
FRC #5860
yup and updated each one's firmware. I even referred to the software manual and it says it is right too, but all we get is blinking orange, unresponsive motors controllers (besides the working drivetrain)
Unread 03-02-2016, 14:45
Cecil's Avatar
AKA: Alex Hummel
Sounds like something on the CAN bus isn't communicating correctly. Could you explain how you have your Talons wired on the CAN bus just as a sanity check? There could be a bad crimp somewhere after your second Talon, or the termination resistor could be in the wrong position.
Unread 03-02-2016, 15:34
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
In your begin.vi, can you check and see if your CAN constants are wired to the right input terminal.
If you used the labview "broom" (last icon on the top icon button menu) to clean up the diagram, you may see that the can id constant is wired to the "master id device number" as opposed to the "device number"
The master id device number is used if the mode is selected to slave.
The sooner we get behind schedule, the more time we have to catch up.
Unread 03-02-2016, 15:43
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Team Role: Coach
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Cecil, I believe we do not have the termination resistor you are referring to. Is this an extra components to add to the CAN network ?
Unread 03-02-2016, 19:26
Coach Seb's Avatar
Team Role: Coach
Rookie Year: 2015
Thank you guys for your help !!!! Alex
Mentioned that he believe one of the answer made sense and he went to our lab to test... He just text me that it worked !!!! Im sure he will be posting his results here in a minute.... Smart kid !!!
Unread 04-02-2016, 07:44
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Good to hear! Good Luck this year.
Unread 04-02-2016, 09:57
Coach/Mentor
AKA: Michael Liang
Glad to hear that it worked. I was just about to post that the code looks good, so it must be hardware! =)
