Go to Post Life is too short to spend 40 hours a week doing something you are not enthusiastic about. - Karthik [more]
Unread 02-02-2016, 22:30
Hsifeulbhsifder Hsifeulbhsifder is offline
Programmer
AKA: Zaeem Mohamed
FRC #5428 (Breaking Bots)
Rookie Year: 2015
Hsifeulbhsifder is on a distinguished road
Where is the C++ Toolchain installed by default on the hardrive
I want to know where the toolchain is installed to from the installer, thanks.
Hsifeulbhsifder
___________________
"Any given computer program is obsolete, any set of written rules is incomplete"
Unread 03-02-2016, 00:30
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Where is the C++ Toolchain installed by default on the hardrive
That would depend on your OS. They are always installed into some folder on the PATH, so if you just need to run them, don't worry about the location, just run them.
Otherwise:
Debian/Ubuntu: /usr/bin/
Mac OS X: /usr/local/bin/
Windows: \frc
On most windows systems that should be on the C drive, but I've seen reports of it being on other drives
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 03-02-2016, 15:18
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
Thank you. I found it installed in a drive other than C:/, so if others have trouble finding it, remember to check all drives.
Hsifeulbhsifder
___________________
Unread 04-02-2016, 13:43
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
It may be the case that you had the install package on a different drive than C: when you did the install. I've heard that there was a "glitch" in the installer that people mostly found by virtue of passing a USB stick around and installing directly from the USB stick which was problematic. I'd suggest copying the install package to C: and then install and see if it winds up in c:\frc
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
