Go to Post How do You Chiefdelphi? :cool: - SpaceOsc [more]
Unread 02-02-2016, 23:10
Loading Loading is offline
FRC #2585
Loading is an unknown quantity at this point
ArnoldC on roboRIO
Many of you are probably already aware that it's possible to write your software in a JVM language other than Java but few have actually tried it. Even fewer have done so with a language as amazing as ArnoldC. Even though ArnoldC is not object-oriented and therefore can't really use WPILib, you can get Java to work with WPILib and get Java source code to link to your ArnoldC code. ArnoldC was originally created to discover the true meanings of Arnold Schwarzenegger's one liners through computer science and now these insights can be further investigated by imagining what the source code for the terminators might look like. You can now program your robot in ArnoldC and hopefully before long, instead of asking "Java, C++ or LabVIEW?" people will ask "ArnoldC or other?" and new meanings from the Arnold movies will be discovered.
https://github.com/KIllinPleaseWait/ArnoldRobot
