Go to Post Our robotics lab has been closed for two days, TWO DAYS! :ahh: - Kevin Selavko [more]
Unread 03-02-2016, 17:20
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
Rookie Year: 2014
amstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to behold
How to configure talon SRX CAN ID?
This is the first year that we are using talon SRX's. I recently figured out that CAN has an ID. Does each motor controller on the chain have an ID? How do I change/figure out what the ID is? I went to the NI Webdash but I couldn't find a place to change the IDs, it only said that the IDs were all the same for each motor controller.
Thanks!
Unread 03-02-2016, 17:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: How to configure talon SRX CAN ID?
Talon SRX User's Manual
Page 9
Unread 03-02-2016, 17:56
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Team Role: Leadership
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
There should be a place on the individual device page to alter the CAN ID. Each device should have a unique ID.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 03-02-2016, 19:34
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
You set the CAN IDs through the RoboRIO web interface.
Once you change the ID on one of the Talons, use the RoboRIO web interface to get it to blink (I don't remember exactly what/where that is) and then stick a label on it so you know its ID.
Unread 03-02-2016, 19:37
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
I recommend reading section 2 of the Talon SRX Software Reference Manual.
http://www.ctr-electronics.com/talon...ical_resources
Unread 03-02-2016, 19:45
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
If you have already wired all of your talons, you should just pull the breakers for them and go through one by one to assign them. It seems like the roborio can only handle a few Talons that share the same ID.
