Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Unread 03-02-2016, 19:26
subzero's Avatar
subzero subzero is offline
SubZero 5690
FRC #5690 (SubZero Robotics)
Rookie Year: 2015
subzero is an unknown quantity at this point
Questions about pneumatic wheel legality
My team has encountered a problem that from what we have read we believe is illegal. Our pneumatic wheels extend beyond our frame which reading Q&A and talking with other teams we have come to the conclusion that this might be illegal. Any thoughts would be greatly appreciated! Picture is in link below.
https://www.facebook.com/photo.php?f...type=3&theater
Unread 03-02-2016, 19:32
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Questions about pneumatic wheel legality
Having things that extend beyond the frame is not inherently illegal. The issue is that things that extend beyond the frame define the FRAME PERIMETER, which may make attaching legal BUMPERS problematic.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 03-02-2016, 19:37
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
R2 and R4 will give you guidance on the FRAME PERIMETER and what can extend beyond it (and when it can).
Unread 03-02-2016, 23:03
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
subzero - it sounds like you have a problem. I'll be one of the LRI's up in Duluth for your event (there are 6 of us between the two events this year... it's overkill, but useful for a week 1 event!), and I just sent you a PM if you want more direct help.
The gist of the rules is that your 120" frame perimeter is determined by wrapping a string around the robot. In this case, it seems that the strings will wrap around the wheels. Is this distance greater than 120"? If it's not, then we have some room to work with. The bigger issue is bumpers - you need to be able to properly mount bumpers outside of those wheels. That means extending some frame into the corners of the robot and the ends of the bumpers (if you do 8" bumpers from each corner. if you cover the entire side, you'll need additional supports). As a second year team, you haven't had to deal with bumpers before... definitely something to get addressed now!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 04-02-2016, 22:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Assuming that the wheel rotates, this is flat out non-compliant. The [convex] frame perimeter must be composed of fixed, non-articulated pieces of the robot. (R2, with convex being derived from the first sentence of R2's blue box.)
Unread 04-02-2016, 22:46
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We are using versaframe to fix this same issue on our bot. Essentially we just have a little U of versaframe attached with Gussets to each corner of the drive train. We had a couple of freshman make it and it looks good.
Unread 04-02-2016, 22:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
another way to fix the problem is to use shorter belts, and move the wheels so they don't extend past the frame.
Unread 05-02-2016, 01:08
longilive longilive is offline
FRC #0321
longilive is an unknown quantity at this point
Put something solid over (above) the wheels and have it stick out barely past the wheels (so you can use it to define the frame perimeter). You can use this as a bumper mount as well.
Unread 05-02-2016, 08:04
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Can you share a picture? As an RI, I would worry that these are not long enough based on the description to support an 8" bumper, but I would have to see it. There are versions of interpretations of you described assembly (such as it is) that are legal, but also some that are not.
Same comment. That would work if the structure is wide enough. Then they would need to be sure their overall frame perimeter is less than 120 as they would have to extend it at least 4" (1" in each corner) based on the picture
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 05-02-2016, 08:59
Sperkowsky's Avatar
Rookie Year: 2014
Sorry when I said little u I meant 26" long u
Unread 05-02-2016, 09:51
Just a nitpick here... But a lot of these posts seem to be saying/implying that something needs to go in front of the wheel. That is not actually the case. Something (greater than 1/2") needs to go into each corner, and that something needs to protrude past the wheel in order to define the frame perimeter. Another something needs to be extended less than 8" from the corner to properly support the bumper, and must extend that support to the edge of the bumper, assuming an 8" bumper (and must be at least 1/2" at the edge). All this can be accomplished without having any frame material in front of the wheels themselves, And actually be accomplished easily assuming there is enough room in the FRAME PERIMETER to accommodate the corner pieces.
