Go to Post We're thinking of using static electricity to pick up the tubes. The programmers are trying to figure out how to make the robot shuffle it's feet on the carpet. - Tom Ore [more]
Unread 04-02-2016, 17:33
BuzzKillerOfFir BuzzKillerOfFir is offline
FRC #1771
BuzzKillerOfFir is on a distinguished road
Strange RoboRio Issue
Our roborio is being detected, but is only accepting code for a second, after that it switches between no code and teleop disabled. We were able to enable teleop for a fraction of a second, and heard the compressor turn on. We were able to successfully able to reimage the rio, and no dice. Please help!
Unread 04-02-2016, 18:14
FTWDragonSlayer FTWDragonSlayer is offline
FRC #4368
FTWDragonSlayer is an unknown quantity at this point
Re: Strange RoboRio Issue
First, check battery voltage. Use the driver station voltage meter, or if you can't get that online for whatever reason, use a voltmeter between battery and Voltage Regulator Module. Then, check the roboRIO's power supply.
Second, check connection - if you can't do wireless, make sure you have a good ethernet cord attached. Try with several if you have them, or check it with another method.
Third, check all OTHER wiring.
Fourth, ask someone who's not trying to get answers out of the team electrician and programmer. (I'm the CAD guy/mechanical/safety captain/various others that aren't electrician or programming)
Good luck,
Team 4368 Bullbots
EDIT: Check your roboRIO firmware, you may actually need to update it.
Unread 04-02-2016, 23:51
jlindquist74's Avatar
jlindquist74 jlindquist74 is offline
WOPR Software Integration Lead
FRC #1622
Rookie Year: 1337
jlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant futurejlindquist74 has a brilliant future
It sounds like your code is dying. Some of our rookie programmers have been having the same problem, and it always turns out they've dereferenced a null or uninitialized pointer.
You can check this by ssh'ing into the roboRIO
Code:
ssh admin@roborio-XXXX-frc.local.
You probably have no password set.
See if your robot code is running (I bet it isn't):
Code:
ps -ef | grep -i frcuserprogram
If it's not running, all you'll see in that listing is "grep -i frcuserprogram". If it IS running, kill that process:
Code:
killall FRCUserProgram
Then run it manually
Code:
cd /home/lvuser
./FRCUserProgram &
Try driving your robot. When it fails, look in the ssh window and see what error shows up. If you see "Segmentation Fault" or "Bus Error", you've done something wrong with a pointer or a reference. It's time to get together with your mentor for a code review.
(This is how we all learn. If someone ever claims to be a C or C++ programmer but tells you they've never had problems with pointers, they're a fraud, and you should run away.)
Unread 05-02-2016, 00:35
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
No code means your code is crashing.
Most likely you are getting to a point when your code crashes upon being enabled. This would likely occur in some code within your Teleop Periodic Function.
Not sure what language you are using, but you can view the output of the RoboRio in many ways. RioLog on Eclipse, or use the serial port and enable console output. http://digital.ni.com/public.nsf/all...257E46005366AE
In your code, Look for a place where you are trying to access a null pointer, most likely in the Telep function, since you are able to turn it on for a split second. The problem is very likely within your own code, and not with the Roborio firmware or image.
hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
