Go to Post Anyone who makes a minibot that poots out another minibot that blows the wall apart deserves to have it displayed in the Smithsonian. - Koko Ed [more]
Unread 04-02-2016, 19:47
troi.dixon troi.dixon is offline
FRC #5919
troi.dixon is an unknown quantity at this point
Exclamation Springs?
Are there any restrictions or limitations on the springs we can use for the robot?
Unread 04-02-2016, 19:53
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Springs?
The only real restriction is Safety. If you use high strength Springs, plan for "spontaneous disassembly". Shield it or run something down the middle to help contain pieces should it break. Do not modify springs - taking a garage door sprin and cutting it in hall is NOT safe. You'll potentially introduce fractures or damage to the spring that would cause it to fail down the road. Don't cut or drill into Springs either - removing material just introduces weak spots!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
