Go to Post You can take the man out of FIRST, but you can't take FIRST out of the man. - George1902 [more]
Unread 05-02-2016, 13:01
iambujo iambujo is offline
Mentor
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
pic: Custom encoder mount for Mini CIM/CIM
Unread 05-02-2016, 13:02
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
Re: pic: Custom encoder mount for Mini CIM/CIM
I like it! Although is there any reason you're direct mounting it instead of on the output shaft of a gearbox or other?
College sux yo
Unread 05-02-2016, 13:10
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
Does that still leave you much space for pinion gear mounting inside a gear box? Very similar to this one.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 05-02-2016, 15:24
Mentor
FRC #2729 (Storm)
I'm not sure, it might not work for some pinion to gearbox applications, but it works well for an 8mm inside diameter keyed shaft (or equivalent shaft adapter).
I hadn't seen the one in the link before! Here I thought we had a novel idea!
Unread 05-02-2016, 15:21
Mentor
FRC #2729 (Storm)
We wanted an option for cases where either a gear box isn't used (like our shooter this year) or another type of encoder mounting just isn't a convenient option.
Unread 05-02-2016, 13:55
jojoguy10's Avatar
jojoguy10 jojoguy10 is online now
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
Originally Posted by iambujo View Post
Actually, according to CUI's datasheet, the maximum RPM is 15,000RPM if you go down to 512PPR
Great design BTW! How much of the CIM shaft is left sticking out?
Unread 05-02-2016, 15:27
Mentor
FRC #2729 (Storm)
Right, it can go up to 15,000 RPM at a lower encoder resolution. I only quoted the range that a mini CIM or CIM could reach, but good catch.
I'll measure the final shaft length tomorrow and let you know.
Unread 06-02-2016, 16:57
Mentor
FRC #2729 (Storm)
There appears to be 13/16" of the shaft remaining.
I didn't get a chance to test the encoder signal today.
Unread 10-02-2016, 19:32
Mentor
FRC #2729 (Storm)
We ran the encoder class on the encoder with the resolution set to 256. We got roughly 25,000 from the encoder class. 25,000ticks x (60sec/min) / (256ticks/rev) = about 5,859 RPMs. Since this was a full speed minicim I'd say the data was valid and I'd say the encoder's resolution is based on rising (or falling) edge and not both. Otherwise the RPM data would not be right.
The beauty of this encoder is that we can set the resolution lower if there was a sampling rate issue, simply with dip switches.
Unread 10-02-2016, 19:56
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
You left out one piece of information crucial to your argument: decoding mode.
Unread 14-02-2016, 00:53
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The mode doesn't change the value, just the resolution. One cycle of the quadrature signals is one count.
Unread 05-02-2016, 15:57
Ether's Avatar
Rookie Year: 1969
What exactly is CUI's definition of "PPR"? "Pulses Per Revolution" is ambiguous.
Do they define it as
  • rising edges per rev on one channel?
  • rising and falling edges per rev on one channel?
  • rising and falling edges per rev on both channels?
Couldn't find the term defined unambigously anywhere on the website or in the product datasheet.
Note: US Digital rates their encoders according to CPR, which they define as "Cycles Per Revolution", which is unambiguous. For example, a US Digital 360 CPR encoder would mean 360 cycles per rev, which is the same as:
360 rising edges per rev per channel
720 rising and falling edges per rev per channel
1440 rising and falling edges per rev both channels
Unread 05-02-2016, 16:26
Mentor
FRC #2729 (Storm)
Good question sir, I'm not sure yet. I plan to test that tomorrow and I will let you know.
Unread 05-02-2016, 16:27
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
if you want to save cnc time and have a 3d printer.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
  #15   Spotlight this post!
Unread 05-02-2016, 17:08
Ether's Avatar
Rookie Year: 1969
The AMT10 has a configurable resolution ranging from 48 up to 2048 at a max of 7500 RPMs
Assuming1 for the moment that 2048 means "rising edges per rev per channel", let's do the math if you set this up for quadrature at 7500 RPM with a 20ms control loop period:
CPR: 2048$
decoding:4$
secondsPerControlLoop: 20/1000$
FPGAsamples: 127$
edgesPerControlLoop: RPM * (1/60) * (decoding*CPR) * secondsPerControlLoop = 20,480
secondsPerEdge2: float((1/RPM) * 60 * 1/(decoding*CPR)) = 0.9766e-6
secondsPerSamplesize: secondsPerEdge * FPGAsamples = 0.1240234375e-3
As can be seen, that is way overkill for operation at that speed.
1 I am inferring that because there are a couple of odd-number PPRs in the list, namely 125 and 385. You can't have an odd number of "rising and falling edges per rev per channel" or "rising and falling edges per rev both channels"
2 This number is even smaller if quadrature tolerance is included. But the 40MHz sampling rate of the roboRIO theoretically should handle it.
