Go to Post I jumped up and yelled when I saw both my teams in the same division. Less running for me in the pits. Thank you, Great Homie in the Sky! - Barry Bonzack [more]
Unread 05-02-2016, 13:35
alexpell00 alexpell00 is offline
FRC #2972
alexpell00 is an unknown quantity at this point
Bumper Rules on a U Bot Chassis
Hello,
We have a U bot design with 5" wide walls at the each end of the U. I wanted to know if we can just cover each 5" section and still be ok with the 8" bumper rules. Does the 8" rule change if there is no chassis there, or do we need to have some internal bumpers? Internal bumps would be pointless but if it is what we need.
Unread 05-02-2016, 13:40
M.O'Reilly M.O'Reilly is offline
AKA: Mike O.
FRC #4637 (BambieBotz)
M.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of light
Re: Bumper Rules on a U Bot Chassis
Before the other sharks get you on this forum, let me answer your question real quick:
You must have 8 inches of bumper extending in both directions from every perimeter-defining corner. The bumper must be backed by the robot frame, so 5 inches is not enough. Internal bumpers are not necessary, and would not be counted.
You can see the game manual for example cartoons. There are also many other threads on ChiefDelphi that explain the rules.
Good Luck!
Unread 05-02-2016, 13:41
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Please read the bumper rules carefully. The bumpers sit along the FRAME PERIMETER, not just the chassis. The FRAME PERIMETER for a U shaped robot is a rectangle - there is no opening or gap in the FRAME PERIMETER. You cannot have "internal bumpers"- they are not bumpers at that point, but part of your robot.
You will need to extend your frame another 3" into the opening of the U in order to get 8" of bumper properly mounted from each corner.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 05-02-2016, 13:42
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
FRC #1675 (Ultimate Protection Squad)
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
In section 4.7 in the game manual, reference "Robot Frame Perimeter C" as an example of exactly what your are referring to.
Unread 05-02-2016, 13:47
Rockant's Avatar
Rockant Rockant is offline
Ray of sunshine
AKA: Ray Amsden
FRC #2823 (Automatons)
Rookie Year: 2013
Rockant is an unknown quantity at this point
So, the bumper rules won't actually change, regardless of the size of your chassis. Basically, your bumpers need to extend at least 8" from each corner of the robot. But, yes, read the bumper rules. They will tell you all you need to know.
Unread 05-02-2016, 13:58
FRC #2972
I read the rules just wanted to make sure before we redesign a bit. Thanks for the clarification!
Unread 07-02-2016, 12:56
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
Rookie Year: 2014
ICE_Bear is an unknown quantity at this point
We were going to have an open front for our robot that's short enough to go under the low bar... We will have about 4.5 inches on each side of the front of our robot that's actually our frame. So we will have nowhere to connect the bumpers on the front. And since our chassis IS our frame since there is no other metal or anything other than electrical wiring above the chassis. What do we do? We have no mentors to help us interpret the rules and help us change our design if we need to.
So basically right now, we have all of the electrical and mechanical stuff set up very basically. We just have a chassis, so with the wheels, the top is at about 5" from the ground. We weren't planning on having a front part of the chassis so that we'd be able to have an attachment to help open the portcullis. So now I'm kinda stuck now trying to understand the bumper rules and see if we can still use our design at all.
Unread 07-02-2016, 13:21
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
The bumper rules are clear on the 8" minimum bumper segments from each corner of the frame perimeter. Unfortunately, as described, your current design will not pass inspection.
If you post a drawing or photo of your existing robot chassis, you might get some suggestions from CD on how to bring your robot into compliance without a major redesign.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 07-02-2016, 13:51
FRC #5875 (ICE)
Rookie Year: 2014
Wouldn't you just have to cover the entire piece that IS there? per R19
Unread 07-02-2016, 13:58
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Read the sentence just before the one you are thinking of in R19 and you'll see why you need at least 8" covered.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-02-2016, 14:00
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
That's not how "side" is defined. The side is from outside corner to outside corner, including any gaps that happen to be in that side. See ROBOT FRAME PERIMETER C (lower left) in Figure 4-3. The FRAME PERIMETER follows the black line around the ROBOT, including the portion spanning the gap. It is marked "NOT OK" since that bottom "U" is less than 8 inches.
(since 2004)
Unread 07-02-2016, 14:20
FRC #5875 (ICE)
Rookie Year: 2014
That was labeled "NOT OKAY" because the corner wasn't covered, not because it was less than an 8" piece of the side.
Since it's our chassis piece that's only 4.5 inches long, wouldn't each individual piece be a side?
Unread 07-02-2016, 14:30
There are two "NOT OK" labels for Figure 4-3 C - one for an uncovered corner, the other for a segment <8".
You are receiving replies from experienced mentors and robot inspectors, you should consider how to address your design issue. If you are not satisfied with the responses from CD, you should post on FIRST Q&A for official clarification.
Unread 07-02-2016, 14:39
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Its fairly simple to determine what size bumpers you need.... use walls and string
Place your robot against wall (without bumpers) that defines a side THEN for each side at least 8 in. of BUMPER must be placed on each side of each outside corner. IF a side is less than 8" entire side must be covered.
So for a U shaped bot the front side would require 8" bumpers per front corner. Thats assuming traditional U-shape with two front corners.
For odd shapes... or to verify corners
Simply wrap a string around the bot (in bumper zone)..any corner of that string shape (frame perimeter) needs an 8" bumper per outside corner side. So its hard to get around 8" rule even with very unique shapes. Either each comer needs 8" bumper side or the entire side <8" needs a bumper, your choice. Anything inside the frame perimeter shape does not need a bumper.
Your extension zone is now 15" beyond original frame perimeter with same shape.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star #21 | Galileo Division #91
  #15   Spotlight this post!
Unread 07-02-2016, 15:57
Team Role: Coach
Rookie Year: 2010
Don't rely on pictures, READ the rules. If you just look at pictures you'll never get the whole story.
Earlier you referenced r19. Read r19. Then re-read r19 just to be sure. I'm on my 7th time through the full manual plus all the other times I have check little items in between. If you read it you'll get your answer and notice every side that is less than 8 inches must be fully covered. You'll also see that you need a minimum of 8 inches covered from each corner.
Andrew Basse
