Go to Post You earn what you work for. - Akash Rastogi [more]
Unread 05-02-2016, 21:03
tedlasai tedlasai is offline
FRC #2996
tedlasai is an unknown quantity at this point
Smile 2 USB Cameras Labview 2016
Hello!
We would like to have a 2 USB camera setup through labview. Last year, we could not do that because the RoboRio had a bug and could not support two USB cameras. We would like to know if anyone was able to implement dual USB cameras in labview this year. Does anyone know if this bug is fixed and 2 USB cameras can be implemented in labview?
Thank You
Sai
Unread 06-02-2016, 08:20
Re: 2 USB Cameras Labview 2016
There are a number of threads related to multiple cameras. Some are more geared towards a switch between two and some towards two simultaneous streams. Some VIs were also posted.
WPILib doesn't natively support multiple USB camera streams. It isn't as much a bug as something that it simply doesn't do. You have the source code, and on another thread, I describe some of the key edits to get this to work. Perhaps it will be a fully supported feature next year, but that depends to some degree on how effective the bandwidth limits are.
Greg McKaskle
Unread 07-02-2016, 09:33
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Our team and some others are working through this same problem on this thread: http://www.chiefdelphi.com/forums/sh....php?p=1532343
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
