Go to Post I love math... :D - Eric W. Jones [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 06-02-2016, 08:58
MeganPowerHawks MeganPowerHawks is offline
FRC #1111
MeganPowerHawks is an unknown quantity at this point
Looking for a new Photo Sensor
We are looking for a digital photo sensor. We previously had the Allen Bradley right-sight 42EF-DIMNAK-A2. Is there any way to modify it to make it a digital sensor? Or, does anyone know of a good digital photo sensor? Thanks!
Unread 06-02-2016, 10:02
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Looking for a new Photo Sensor
What makes you believe it isn't a digital sensor?
Unread 06-02-2016, 10:12
FRC #1111
When testing, we were getting a range of values rather than just 1 and 0. We're working on it right now, but from what we can tell, it doesn't return boolean values in the code.
Unread 06-02-2016, 12:12
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
How do you have that 42EF-DIMNAK-A2 wired to your roboRIO?
... and how are you reading it in your code?
Unread 06-02-2016, 19:08
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The 42EF-DIMNAK is digital, but it is designed for operation using 10.8 to 30V, not 5V. See this thread for more details.
Unread 06-02-2016, 20:58
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
In a general context, however... and note that there are likely better solutions in this specific case based on what I've read above... but in a general context you can turn an analog input into a digital output by using a comparator https://en.wikipedia.org/wiki/Comparator
There are a number of cheap op-amp/comparator chips out there... you feed your analog sensor into one input on the comparator, and use a potentiometer as a voltage divider on the other input to provide a reference voltage. When your input voltage exceeds the reference voltage, your signal goes high (or low, if you want to hook it up that way).
Google a bit and you'll find sites like this http://home.cogeco.ca/~rpaisley4/Comparators.html but maybe check out some of the options above before using this solution in this specific case.
Jason
Unread 08-02-2016, 08:52
Richard100 Richard100 is offline
FRC #0836 (RoboBees)
Richard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to behold
Megan - For a digital photo sensor, we like the DFRobot IR sensor, it is adjustable to trigger at distances from 3 to 80 cm. Runs on 5VDC for $7.50. Part number SEN0019, DFRobot.com. No affiliation.
We can give you one of ours if you like, so you can try it out. PM me or contact us through team836@robobees.org.
Unread 08-02-2016, 09:05
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
AutomationDirect has lots of different kinds of photo sensors.
Use your KOP voucher to take $30 off ...
AutomationDirect Sensors
Make sure you order an NPN output version and that it runs on 12Vdc.
Unread 08-02-2016, 09:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Seconded. These are nifty little doodads. Reminds me that I need to order some for some automation tasks on the robot....
