Go to Post any robot that can hold and transport its team has found its purpose and can be considered complete - Nitroxextreme [more]
Unread 02-06-2016, 09:08 AM
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Thrifty Throttle - 12 volts?
The Thrifty Throttle 2 (am-2936a) takes a 9v battery. Anyone have any idea if we can wire it to 12 volts?
http://www.andymark.com/Thrifty-Throttle-p/am-2936a.htm
Unread 02-06-2016, 09:20 AM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: Thrifty Throttle - 12 volts?
Without knowing the voltage regulator input rating, I can't say. Best to stick with what it's designed to use though.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 02-06-2016, 09:23 AM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
Looks like it has a voltage regulator, but no guarantee that it it would take 12v. If you want to risk letting the smoke out, have at it.
Seems easy enough to put a 9v battery on.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 02-07-2016, 03:33 PM
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
Team Role: Teacher
Rookie Year: 2012
amesmich is an unknown quantity at this point
Or you could make a simple inefficient voltage divider. It cant draw that much current.
Unread 02-08-2016, 03:04 AM
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Team Role: Coach
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
The more common 5v VR is capable of accepting and input voltage range not one specific voltage. This one for example https://www.sparkfun.com/products/107 has an acceptable input range of 8-20v. It of course it not the one used on the thrifty throttle, it is just the first one that showed up in a search. If you can find the part number of the one used in the Thrifty Throttle then you can check it's data sheet.
The other option is the diode trick. A silicon diode has a voltage drop of about .7v so string together 5 of them in series between the nominal 12v battery which is actually 12.6~12.7v when fully charged and you'll have a ~9v input to the Thrifty Throttle. If you are using it for testing that will have a significant load that will cause significant voltage sag on the battery then you may want to use only 4 diodes.
All statements made on Chief Delphi by me are my own opinions and are not official FIRST rulings or opinions and should not be construed as such.
https://www.facebook.com/pages/Team-...77508782410839
Unread 02-08-2016, 07:44 AM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
If the voltage regulator were to accept the higher voltage it would come with increased temperature. The 9 volt battery is such an easy item to obtain why worry about other voltage sources.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 02-08-2016, 09:51 AM
JerryBudd JerryBudd is offline
JerryBudd is an unknown quantity at this point
The Voltage Regulator on the Thrifty Throttle 2 Board is rated for 18V.
However, we do not recommend using more than a 13V input.
Unread 02-08-2016, 10:03 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Go for it! 18v rating, minor temp increase (the temperature increase is dependent on load, isn't it? so something with a very small load like this won't have much of a temperature increase).
It's ok to use an inefficient voltage regulator, when you have way way more power available than you need.
But keep in mind I'm a mechanical engineer, not an electrical engineer, and I treat electronics in a practical way, not a theoretical way
Unread 03-07-2016, 12:46 PM
Rookie Year: 2012
I finally received a reply from Andymark. Apparently their new ticket system was sending a lot of messages to their Spam folder, and they just found out today.
"The Thrifty Throttle can handle up to 13.5V"
