Rhino track failier?
My team purchased the Rhino Tracks from Andy-Mark this year, but after driving with them, the pulleys (am-3298) have started to fall apart. The plastic is chipping around the bearing. Is anyone else having similar issues?
Re: Rhino track failier?
sorry pic in not working
Try attaching the image to the post as an attachment, or linking it differently.
[IMG]blob:https%3A//mail.google.com/82aaea0c-d18f-40c0-8001-74d3ed496baf[/IMG]
copy this link into google without the [IMG]
Try again. Link does not work at all.
Upload your image to imgur.com and provide the link here. We're not logged into your Google account, so we can't see images in your email.
there it is, thanks
#10
Did you use locate when you assembled them? Because that looks. Exactly. Like. When a student used locate on our wheels. One year some got. On the plastic and the locktite eats. A. Component of the plastic. And they fall. Apart
#11
We just had the same breakage today. We are checking for more signs of weakness. Did you have more than one break??
#12
these wheels where assembled with 6 bolts, 3 per side. we followed the manufactures construction. I think that it may come from a combination of over-tightening of the the track, or the force of the robot slamming into the ground after crossing a defense. We have broken 5 of these wheels so far. Is this happening for anyone else?
-thank you for any info you can give |
#13
We haven't done a lot of defense crossing yet. Today we were code testing when we found the broken piece. We weren't even sure where it came from until I read your question. Keep us posted
![]() *update we found cracks on several wheels, some are in advanced stages but not broken yet. placement on the track was not a factor. we also do not believe it is a tension issue. Last edited by callmecairo : 06-02-2016 at 16:08. |
#14
Some plastics react badly (called crazing) to superglues (CAs in particular) and Loctite. The bearings should be a slight press-fit into those pullys and should not need any glue. If they are a little loose, use a fender washer and spacer to keep them there. |
#15
no adhesives, only bolts. this is a very dense plastic, when it breaks it cracks it is a lot like obsidian, it forms very shiny surfaces
