Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 06-02-2016, 13:10
Coupon4504 Coupon4504 is offline
FRC #4504
Coupon4504 is an unknown quantity at this point
CAN Transmit Error and standard output
I have created a function that calculates the I part of PID and then outputs the data to the console to create a graph and analyze different constants (Ki). This is a side project while we wait on build to finish what they are working on. The integral function works, but when I add it to our Sample Robot, it fails for multiple reasons: I get the error below when running the test code, and The output does not go to the console unless I go into teleop mode.
Why is the output delayed and why did this error occur? Any easier ways to output data? File I/O does not work. I have tried using cout and printf, and both have this problem. Usually cout works better
FRC: Robot radio detection times. Error on line 238 CTRE CAN Transmit Error
at /home/lvuser/FRCUserProgram() [0x1fcc4]
at /home/lvuser/FRCUserProgram() [0x27904]
at /home/lvuser/FRCUserProgram() [0x87210]
at /home/lvuser/FRCUserProgram() [0x898f0]
at /home/lvuser/FRCUserProgram() [0x9a3cc]
at /home/lvuser/FRCUserProgram() [0x9499c]
at /home/lvuser/FRCUserProgram() [0xc0804]
at /opt/GenICam_v2_3/bin/Linux_armv7-a/libstdc++.so.6(+0xa2cb0) [0xb6af1cb0]
Code:
double integral(double angle, double x)
	double result = 0;
	int n = 1;
	result += gyros[0];
	if(x > 0.1)
		for(double i = 1; i <= x * 10; i += 1)
			result += 2*gyros[i];
			n++;
	result += angle;
	result *= x/(2*n);
	std::cout << result << '\n';
	return result;
void Test() override
	for(int x = 0; x < 10000; x++)
		double angle = gyro->GetAngle();
		myRobot->Drive(0.15, -Kp*angle );
		gyros.push_back(angle);
                std::cout << x << ' ' << Kp*integral(angle, x) << ',';
		printf("%d %e,", x, Ki*integral(angle, x));
		Wait(0.01);
        myRobot->SetLeftRightMotorOutputs(0.0, 0.0);
