Go to Post Building a robot is one thing - but the fun I have had with my mentors, parents, and other students on team outings is something I cherish. - SuperJake [more]
Unread 06-02-2016, 14:45
W.F.G.B. W.F.G.B. is offline
FRC #5940
W.F.G.B. is an unknown quantity at this point
Question Nav-x not working
Our team's navx doesn't seem to work at all. I am not able to update the firmware on it. I followed all of the given instructions. When I do it, I get this error:
Inside the details box:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.DllNotFoundException: Unable to load DLL 'STDFUFiles.DLL': The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail. (Exception from HRESULT: 0x800736B1)
at NetDFULib.HEX2DFU.STDFUFILES_CreateNewDFUFile(Stri ng szDevicePath, IntPtr& handle, UInt16 Vid, UInt16 Pid, UInt16 Bcd)
at NetDFULib.HEX2DFU.ConvertHexToDFU(String hex_file_name, String dfu_output_name, UInt16 Vid, UInt16 Pid, UInt16 Bcd) in c:\Users\Scott\Documents\GitHub\navxmxp\c#\NetDFUL ib\HEX2DFU.cs:line 27
at navXFirmwareUpdater.Form1.button1_Click(Object sender, EventArgs e) in c:\Users\Scott\Documents\GitHub\navxmxp\c#\navXFir mwareUpdater\Form1.cs:line 569
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
navXFirmwareUpdater
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Kauai%20Labs/navX-MXP/navXFirmwareUpdater/navXFirmwareUpdater.exe
Win32 Version: 4.0.30319.34250 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.34262 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.34239 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
NetFULib
CodeBase: file:///C:/Program%20Files%20(x86)/Kauai%20Labs/navX-MXP/navXFirmwareUpdater/NetFULib.DLL
navXComUtilities
CodeBase: file:///C:/Program%20Files%20(x86)/Kauai%20Labs/navX-MXP/navXFirmwareUpdater/navXComUtilities.DLL
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I tried looking the error up on google, and I only got one thing and it was non-FRC related.
I found STDFUFiles.DLL and put it in Windows\System32 and tried to register it with regsvr32, but it instead said that it "couldn't find STDFUFiles.DLL".
I tried it on Windows 10 and 8. Neither of them worked and they gave me the same error.
Is there anything I'm missing here?
Thanks,
W.F.G.B.
Unread 07-02-2016, 01:15
slibert slibert is offline
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Re: Nav-x not working
mscorlib
navXFirmwareUpdater
System.Drawing
System
NetFULib
navXComUtilities
System.Core
System.Management
enabled.
For example:
<configuration>
</configuration>
Thanks,
W.F.G.B.
From your description (the details are very helpful) it appears that one of the device drivers that are installed when you run the NavX-MXP setup.exe program did not successfully install.
This can occur if the user you are logged in as when you install the software does not have sufficient privileges to install a device driver. *Please ensure you have run the setup.exe as administrator*, which should allow the signed driver (which allows firmware to be installed to the NavX-MXP) to be installed correctly.
Unread 12-05-2016, 00:03
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
I just ran into what appears to be the exact same problem, and for me the fix was to install Visual C++ 2005, which is available here: https://www.microsoft.com/en-us/down...s.aspx?id=3387
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
