Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
Unread 06-02-2016, 15:21
cschulman cschulman is offline
FRC #0028
cschulman is an unknown quantity at this point
ever seen this gearbox
I found this gearbox. Has anyone seen this before? We are thinking of using this as an intake.
Unread 06-02-2016, 15:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: ever seen this gearbox
Yes. That is a BaneBots CIM-U-Lator
Unread 07-02-2016, 11:19
FRC #0028
Thanks. Do you have any experience using them with the motor shown in the pic?
Unread 07-02-2016, 14:12
Team Role: Teacher
They had a dual-motor version we've used with two BaneBots 550 motors. The AndyMark 9015 is a very similar 550-can motor. As long as the gear fits the shaft, and the shaft is not too long, it should work.
Unread 08-02-2016, 08:51
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
SandDrag is correct - it is a Banebots CIM-U-lator. That particular gearbox had a serious design flaw. The small 550 and 775 motors have active cooling and use a fan to draw air in from the front vents, blow it past the armature and out vents near the rear. That gearbox covered the intake vents and motors burned up. The original 775 motors got a bad reputation for being unreliable when the real issue was this specific gearbox.
There was a modification (proposed by Andy Baker if I remember) that milled slots in the mounting surface to allow air to the vents. From the picture, it does not look like your geabox has been modified. Otherwise a fine gearbox - Vex and Andymark both have similar gearboxes which have air vents by design if you dont have the ability to modify the one you have.
Unread 08-02-2016, 09:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If I recall correctly, the original RS-775-18V had a case short problem after just a few minutes of run time. I can't dig through 15 pages of that thread right now, but somewhere in there someone did a pretty thorough post-mortem of the motor.
This was the eventual solution.
The new 775PRO is not a RS-775-18V. There is a big distinction. I can honestly say that our 775PRO's have run for roughly an hour already as we tuned shooter geometries, and they've been very stable with not even a modicum of excess heat.
With that said, the 775PRO is compatible with the CIM-U-Lator, but I would definitely file/mill/do-what-it-takes to make the air vents, as you mentioned.
GitHub
Unread 08-02-2016, 11:28
FRC #1559
Yes, the original 775 also had a case short issue which we were fortunate not to run into. That issue was amplified by the overheating. We did fry at least three motors before finding the root cause of the overheating. Obviously since the OP was for 775pro, this case short will not be an issue, but overheating definitely will.
I did find the thread on the milling process. If you do a search for "cimulator cooling modification", we used the mod from J_Miles with great success - motors went from letting out magic smoke to warm to the touch.
