Go to Post Sometimes it is worth it to stop and read what you've written before posting. - [more]
Unread 06-02-2016, 16:18
David Lame David Lame is offline
FRC #0247
David Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the roughDavid Lame is a jewel in the rough
Grip and performance on the driver station laptop
We have successfully been using GRIP on the driver station. We want to do more with it.
Does anyone have information or experience with PC performance, GRIP, and processing power? We seem to get some lag. It isn't too bad for what we are doing, but we're a bit nervous about it in competition. It might be network latency, but it doesn't seem to be as bad if we are just viewing a camera feed in the smart dashboard.
Anyway, we were wondering if beefing up the PC might be likely to improve things. Does GRIP take advantage of multiple cores? An available graphics card that could be used (at least in theory) to handle OpenCV calls? A higher speed processor? Just curious if anyone has some advice on system requirements or recommendations if using GRIP on the driver station PC.
Unread 06-02-2016, 16:43
Turing'sEgo Turing'sEgo is offline
Rookie Year: 2010
Turing'sEgo can only hope to improve
Re: Grip and performance on the driver station laptop
There is a fairly easy way (and relatively accurate) to tell if a program utilizes multiple cores: run it an check the usage of your cores. It works better in linux because the OS is much lighter.
At the heart of GRIP is opencv. GRIP isn't the problem with performance as it is really just a gui for opencv.
Have you tried compiling opencv to support multiple cores?
Unread 06-02-2016, 17:00
FRC #0247
The long term plan is to use OpenCV on a coprocessor, but we don't know if it will be done before our week 1 competition, so we might have to deal with the driver station at the first competition.
Unread 06-02-2016, 17:31
Rookie Year: 2010
Opencv has either inherent threading with openmp in linux (not sure about windows) and it has a TBB API that I know can be utilized in windows. If you need help with this I'd be glad to help.
Unread 07-02-2016, 15:23
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
GRIP uses multiple threads to capture video, run algorithms, and render the GUI, but the computer vision stuff is all in one thread. So, you might benefit from multiple cores, but only up to a certain limit.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
