Go to Post This is the best experience you will ever get. - Arefin Bari [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 06-02-2016, 17:06
moomoomoo309 moomoomoo309 is offline
FRC #0224
moomoomoo309 is an unknown quantity at this point
Vex Ultrasonic Range Module
We tried finding distance using this module, and after connecting it correctly, it keeps either not working (isRangeValid() is false, returns 0 on getRangeInches() and getRangeMM()) or returning infinity (isRangeValid() is true, returns Double.POSITIVE_INFINITY (the infinity symbol) from getRangeInches() and getRangeMM()). Has anyone else had luck getting one of these working in Java? It's hooked up to the DIO ports currently.
Unread 06-02-2016, 20:52
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: Vex Ultrasonic Range Module
Is there a good target in front of it? If yes, at what distance?
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 11-02-2016, 17:28
FRC #0224
I placed it facing towards the floor, within a few inches (<10). It continued to return ∞. I rebooted the robot, and hasDistance() returned false, and it returned 0 again. (I haven't changed how I wired this sensor!)
