Go to Post It's a club if you have a bunch of people who hang out and do nothing - It's a team if all you all work together and cooperate to win. - Tytus Gerrish [more]
Unread 02-06-2016, 06:53 PM
rubberducky rubberducky is offline
FRC #4587
rubberducky is an unknown quantity at this point
Drive Station not connecting to roboRIO
Hi, our drive station won't connect to the roboRIO. We have two laptops running windows 7, all of the software is updated for 2016 FRC. Laptop 1 can ping, web interface (internet explorer "roboRIO-4587-FRC.local"), and connect through drive station to roboRIO. Laptop 2 can ping, web interface, but the drive station doesn't connect. The only error message that we're getting is: 44004 error is: FRC: The Driver Station has lost communication with the robot. Has anyone else ever had this problem? Or even better, know the solution?
Unread 02-06-2016, 07:13 PM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Drive Station not connecting to roboRIO
Disable all firewalls and anti-virus.
Double check the team number on the Setup tab.
Click on the down arrow next to the team number on the Setup tab to see what's listed there.
Check the ping lights on the Diagnostics tab to see what the Driver Station is able to ping.
I assume the Driver Station Communications light is red?
Unread 02-07-2016, 09:26 AM
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Are you trying to run both driver stations at once? The robot will only connect to one of them, the first one it sees.
Unread 02-08-2016, 12:39 PM
mrbrenzo mrbrenzo is offline
FRC #1829
mrbrenzo is an unknown quantity at this point
I have just troubleshot this to. I could ping, but not control the robot. we troubleshot using the following steps;
1. check ping
2. try to drive it by hooking your driver station to the radio with an cat5 cable. if that works, you have validated your network settings. if driving with the cat5 cable does not work it is a network setting.
ours worked when using the cable. turns out our wifi adapter on the driver station was so old, it would do the network settings, but could not support the bandwidth. good luck
