Go to Post -Our engineering mentor, Mr. Wittel- *crossing arms and sitting down* "Ahhh. I love work. I could watch it all day." - OverdriveAdge [more]
Unread 06-02-2016, 19:20
boz336 boz336 is offline
Electrical Engineer/Mentor
FRC #1599 (CircuiTree)
Rookie Year: 2012
boz336 is an unknown quantity at this point
ADXL345 I2C Example Code Troubles
I've had most other sensor example code working fine. Including the Analog Devices Accel Gyro combination on the SPI port. But for some reason, I can't get the I2C port working for the example.
The following error comes up at run time:
Errors were detected in the target log when connecting to the target:
LabVIEW: (Hex 0x661) The LabVIEW Real-Time process encountered an unexpected error and restarted automatically.
Ideas? Thanks in advance.
Unread 08-02-2016, 12:20
reuven reuven is offline
FRC #3211 (The Y team)
reuven will become famous soon enough
Re: ADXL345 I2C Example Code Troubles
Hi,
i'm haveing the same error with the same exmple (the I2C does not work)
any leads?
thanks
בנגב יבחן העם בישראל" דוד בן גוריון"
"In the Negev the people of israel would be tested"-David Ben Gurion
