Go to Post "Who needs finesse when you have air pressure?!" - neelpatel1710 [more]
Unread 06-02-2016, 19:48
simon1636 simon1636 is offline
FRC #4501
simon1636 is an unknown quantity at this point
More Solenoid Trouble
Hey guys! I am having trouble coding the solenoid. I want it to be so that whenever I push on the buttons on the top of the Attack 3 joystick, the solenoid opens up. The button labeled 3 on the Attack three opens the solenoid forward and the button 2 opens the solenoid backwards. However, my code does neither of this. In fact, I'm not sure if it's the code or not, but the air only come out of hole 2 of the solenoid. If you see anything that would be affecting the situation so that it doesn't work, let me know!
Code:
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.SimpleRobot;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SimpleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class RobotTemplate extends SimpleRobot {
     * This function is called once each time the robot enters autonomous mode.
    Jaguar lTalon,rTalon;
    Joystick throttle;
    DoubleSolenoid exampleDouble;
    Joystick aimer;
    public void autonomous() {
     * This function is called once each time the robot enters operator control.
    public void robotInit(){
        lTalon=new Jaguar(3);
        rTalon=new Jaguar(4);
        throttle=new Joystick(1);
        exampleDouble=new DoubleSolenoid(1,2);
    public void operatorControl() {
        while(isOperatorControl() &&isEnabled()){
           lTalon.set(-throttle.getZ());
           rTalon.set(throttle.getZ());
        if(aimer.getRawButton(3)){
            exampleDouble.set(DoubleSolenoid.Value.kForward);
        else if(aimer.getRawButton(2)){
            exampleDouble.set(DoubleSolenoid.Value.kReverse);
        else{
            exampleDouble.set(DoubleSolenoid.Value.kOff);
     * This function is called once each time the robot enters test mode.
Unread 06-02-2016, 20:17
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
Rookie Year: 2014
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: More Solenoid Trouble
All the code that should run during teleop should be placed in the while loop.
Unread 07-02-2016, 17:07
FRC #4501
So I changed it so that all the Solenoid code is in the while loop, but it still isn't working! Do any of you guys see anything else wrong with the code?
Code:
/* the project.                                                               */
 * directory.
    Joystick throttle;
    Joystick aimer;
        if(aimer.getY()>0){
        else if(aimer.getY()<0){
        else{
