Go to Post Nothing is perfect - but AM is a phenomenal company! - iambujo [more]
Unread 06-02-2016, 22:31
Team2895's Avatar
Team2895 Team2895 is offline
FRC #2895 (Blazenbotz)
Team2895 is an unknown quantity at this point
Having trouble with cim motors
So let me just start by saying that we're using spark motor controllers for the motors they are the motors are regular cim motors working with the drive train so the problem we are having is that one side is going faster then the other please help us
Unread 06-02-2016, 22:36
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Captain
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Re: Having trouble with cim motors
I hate to say this... but is your code fine? That's the first thing I would check. After that, try calibrating the sparks.
User manual:
http://www.revrobotics.com/wp-conten...1200-UM-00.pdf
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 06-02-2016, 22:50
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
Team Role: Mechanical
Rookie Year: 2013
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
It could be as simple as a loose connection meaning that one motor on a side isn't receiving power, also depending on which gearboxes you are using one, could have been fitted with a slightly different gear ratio than the other?
Unread 07-02-2016, 12:07
MetaEngineer's Avatar
MetaEngineer MetaEngineer is offline
Director of magic smoke
AKA: Barden
FRC #0246
Rookie Year: 2010
MetaEngineer is an unknown quantity at this point
Are the motors new or have you used them on a previous year's robot?
Does the problem follow one motor regardless of motor controller? Or does the same motor controller always run the motor slower?
What about friction in the drivetrain? Does the slower side feel more difficult to turn by hand?
