Go to Post I guess I'm a bit of an apple fanatic. - Austin [more]
Unread 07-02-2016, 22:02
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Team Role: Mechanical
Rookie Year: 2015
arc25565 is an unknown quantity at this point
Re: Good #25 chain breaker?
At the beginning of the season we purchased a chain breaker very similar to the one you found on amazon. I was very disapointed as it broke after a couple of uses. We then switched to using a dremel to grind off the pins and it has worked very well.
Unread 08-02-2016, 20:48
HighlandersFRC HighlandersFRC is offline
Team mentor
FRC #4499 (The Highlanders)
HighlandersFRC is an unknown quantity at this point
Here is a team created #25 chain break (our commercial one did not work well, bent the chain and was very difficult to use).
Picture one shows it in action. Picture two show a .1" hole about .75" deep in a 3/8"-16 bolt with lock nut inserted in a 1 1/8 long nut. The cut out in the nut is 3/8" long and 3/8" deep (cut on mill). Picture 3 shows the other 3/8" bolt with a .900" hole drilled about .5" deep with a piece of .900" HHS (like the back of a small drill bit) Loctite in place. We TIG welded a handle on and use this in a small vise. Takes about 20 minutes to create.
Works great and fully supports the chain.
ID:	20012  Click image for larger version
ID:	20013  Click image for larger version
Mentor on team #4499 The Highlanders
2016 Arizona North Engineering Inspiration Award Winners| Colorado Regional Finalists | Colorado Chairmans Award Winners
2015 Colorado Regional Chairmans Award | Colorado Regional Finalists | Woodie Flowers Finalist - Tony English | Dallas Regional Quality Award
2014 Inland Empire Engineering Inspiration | Colorado Regional Engineering Excellence
2013 Hub City Rookie All Star | Colorado Regional Rookie All Star | Colorado Regional Highest Rookie Seed
